BOOST!!!
Old Dec 4, 2001 | 01:16 AM
evil_elmo's Avatar
Default BOOST!!!
i'm wondering a standard b16a computer can you run 7psi of boost?? if you can how do you do it??
THANKS
Old Dec 4, 2001 | 02:40 AM
D-SPEED's Avatar
Default Re: BOOST!!! (evil_elmo)
honda ecu does not read boost unless modified....otherwise you must "hide" the boost from it
Old Dec 4, 2001 | 12:06 PM
evil_elmo's Avatar
Default Re: BOOST!!! (D-SPEED)
so how to you hide boost??
Old Dec 4, 2001 | 12:10 PM
D-SPEED's Avatar
you can do it a few different ways. A common way is to use check valves or a "missing link"...it bleeds of boost from the vacuum line before it reaches the MAP sensor. If your stock MAP sensor reads boost, your ECU will throw a code.
viper_boy403
Engine Management and Tuning
15
Jun 15, 2014 08:17 AM
Hiboost 2.0
Apr 17, 2013 08:14 PM
adam00
Sep 1, 2009 05:49 PM
redlinetuning
May 7, 2009 08:41 AM
junyekh22t
Jun 8, 2006 07:02 AM
