bogging in boost?
Old Sep 25, 2003 | 08:10 PM
chinners10's Avatar
Default bogging in boost?
i have some lag when i reach boost.... if i get a fuel rail, and FPR, will that help it alittle??? i don't know what else it would be, i have an FMU...
Old Sep 25, 2003 | 08:22 PM
r7's Avatar
r7
Default Re: bogging in boost? (cxhatch02)
too rich?
Old Sep 25, 2003 | 08:26 PM
chinners10's Avatar
Default Re: bogging in boost? (r7)
my Air fuel guage read lean, only one bar shows up on my guage
so i dont know..
Old Sep 25, 2003 | 08:29 PM
DaveF's Avatar
do you have a high pressure inline fuel pump hooked up with the fmu?? if so..are you sure its running(the fuel pump)?
the fpr will do nothing if you are running the fmu setup..it would only be good while you were in vacum.
Old Sep 25, 2003 | 08:30 PM
B94Cast's Avatar
If your gauge is setup properly, and you are only reading 1 bar in the lean, then something else is not...
I would check to ensure that your gauge is hooked up properly first.
Does it always stay at 1 bar showing only? Is this a Autometer gauge?
Old Sep 25, 2003 | 08:32 PM
DaveF's Avatar
Default Re: bogging in boost? (B94Cast)
the autometer a/f guages are worthless
Old Sep 25, 2003 | 08:37 PM
chinners10's Avatar
Default Re: bogging in boost? (2.2Lcivic)
yea its autometer...but it should just register.....when i start it... the guage scrolls through all the colors, but then at idle it stays at lean
Old Sep 25, 2003 | 08:41 PM
B94Cast's Avatar
Well two things - when you are idling, it should sweep slowly back and forth. The second, when you are a full throttle out of or in boost, it should be in the rich area. If it never moves no matter what - then check to ensure it is hooked up properly. If it is - check your fuel system top to bottom, including your O2 sensor.
Old Sep 25, 2003 | 08:44 PM
R6Elmo's Avatar
Check teh voltage from the 02 sensor. It should be 0.1V lean and 0.9V rich. It should go back and forth at idle. An a/f gauge is basically a big voltmeter is all.
As for your bogging. Check your plugs too. Check to make sur ethey aren't fouling, or missing under boost.
Normally bogging is from being too rich though.
Old Sep 25, 2003 | 08:46 PM
chinners10's Avatar
Default Re: bogging in boost? (R6Elmo)
cool.........thanks, should i re-gap my plugs also?? widen the gap or make it smaller?? and i recheck my wires to the o2 sensor....
Old Sep 25, 2003 | 10:46 PM
r7's Avatar
r7
what psi? whats the gap @ now? .. mine are @ 0.030 @ 7psi
Old Sep 26, 2003 | 08:15 AM
chinners10's Avatar
im boosting at 5psi and the plugs are gapped at .045
vtec_killer_
Feb 17, 2008 10:06 AM
SOHC_power
Oct 30, 2002 10:10 AM
HybridCoupe
Jul 11, 2002 12:38 AM
RATEDR
Jul 9, 2002 12:26 PM
ludelvr
Jun 19, 2002 02:53 PM
