problems with fuel under boost leaning out
Old Oct 29, 2002 | 04:30 PM
SOHC_power's Avatar
Default problems with fuel under boost leaning out
o.k. i have the the drag gen3 kit with the vortec fmu. i am having problems with the fuel leaning out. it just started doing it. the turbo sounds like it it is spooling up and i can hear the blow off valve, but it never reads positive boost. i can stomp it to the floor, and it stays rich until it gets to 3500rpms(about when it would start boosting) and then the a/f goes in the red. it sounds like it is making positive boost, but it is not. it only leans out at wot. but it never makes boost. could my fmu be screwed up? i don't have a stopped up vacuum line, because the boost guage will go up to zero, but not past. i don't have egt or fuel pressure gauges. please help
Old Oct 29, 2002 | 07:27 PM
SOHC_power's Avatar
Default Re: problems with fuel under boost leaning out (SOHC_power)
no suggestions?
Old Oct 29, 2002 | 08:20 PM
ELUD THS's Avatar
New User
do you have an inline fuel pump to support your fmu??
Old Oct 30, 2002 | 03:42 AM
SOHC_power's Avatar
Default Re: problems with fuel under boost leaning out (ELUD THS)
yes 125psi
Old Oct 30, 2002 | 07:52 AM
TheIntegraGuy's Avatar
What kind of A/F gauge do you have? Some aren't as accurate as others. Try using an exhaust temp. gauge and see if you're leaning out.
Old Oct 30, 2002 | 10:10 AM
SOHC_power's Avatar
Default Re: problems with fuel under boost leaning out (Esone3)
i know they are not that accurate, but everything was working fine. at wot it used to stay on the rich side, now it goes straight to the lean side and the car does not accelerate. it's not a question of whether or not it it leaning out, but why is it leaning out. i ordered my fuel pressure guage last night, so that maybe that will give me an answer when i get it hooked up.
[Modified by SOHC_power, 1:11 PM 10/30/2002]
vtec_killer_
Feb 17, 2008 10:06 AM
swpdb16
Oct 20, 2004 07:01 PM
chinners10
Sep 26, 2003 08:15 AM
SOHC_power
Oct 30, 2002 03:43 AM
BoostedSi
Jan 14, 2002 09:00 AM
