how much boost?
Old Oct 13, 2011 | 08:03 AM
typerturbo29's Avatar
Icon2 how much boost?
So ill have the money by spring to get my motor together (b18c1 block with b16a head) my question is with 440cc injectors and upgraded block and headstuds. what would be a good goal for boost 10-12psi?
Old Jan 11, 2012 | 05:43 AM
Default Re: how much boost?
bump for better question than before
Old Jan 11, 2012 | 05:57 AM
kyden's Avatar
still not enough info, but those injectors are only good for 300whp max.
Old Jan 11, 2012 | 12:27 PM
stock head pr3
block b18c1 eagle rods, cp 9.8 cr pistons
aem fpr, aem fuel rail, walbro 255, and have a set of precision 440cc injectors
so if im looking for more than 300, say 350 i would need at least 550s?
Old Jan 11, 2012 | 04:35 PM
crvtectim's Avatar
It's hard to say until you're staring at the injector's duty cycle.
Old Jan 11, 2012 | 04:58 PM
dantamparacer's Avatar
man up and buy real injectors. If you buy new 525cc -880cc are the same price, but if you drop an extra $20 you can get 1000cc. Stock sleeves are your limit with the build that you have listed other than injectors. Spend the money in the fuel system and you should be ok to about 500whp if you have a turbo the will do it.
http://www.xenocron.com/injectors-pr...s-c-30_59.html
Old Jan 12, 2012 | 07:15 AM
thanks, ill have to look into some bigger injectors then. any opinions on precision vs rc? and im aiming for 350whp maybe more down the road when i get headwork+cams etc so maybe the 650s?
Old Jan 12, 2012 | 07:42 AM
Go_Race_Your_Self's Avatar
Two Piece
Get ID injectors.
Kev
Old Jan 12, 2012 | 09:43 AM
Boost4Breakfast's Avatar
just get some 880's or 1000's. you can always tune "down" larger injectors and you will have some room to grow. 440's are really just for ebay-kit'd d16's.
DrivinVtec
Jul 21, 2006 08:22 AM
crxcrazysi
May 22, 2006 02:43 PM
AznBlueBoy
Mar 1, 2006 12:03 AM
Spooled1.6L
Sep 25, 2003 08:46 AM
2ltrsnailpwr
May 26, 2003 04:49 AM
