Blown Head gasket and stripped block?
Old Aug 31, 2004 | 11:58 AM
CATCH DIS HATCH's Avatar
Default Blown Head gasket and stripped block?
After blown my head gasket due to turbo, three of the head bolts was loose (around the number one cylinder). Took my head to the machine shop getting it resurf, compression check, and getting new head gasket. Now on the installation, torque the head down I notice the three bolts around the #1 cylinder is stripping. I check the bolts (seeing pieces of metal around the threads). The block might be stripped. Is there any way I can fix the thread on the block? help me out guys
Old Aug 31, 2004 | 12:00 PM
DaveF's Avatar
Default Re: Blown Head gasket and stripped block? (CATCH DIS HATCH)
you have to drill the block and heli coil it.
b18bturbo's Avatar
use a time sert and insert it into the block similar to a heli coil but not as good.
Old Aug 31, 2004 | 12:03 PM
Default Re: Blown Head gasket and stripped block? (b18bturbo)
can I do it myself. Or I have to bring it to the machine shop. what is a heli coil? where can I get one at? how much
Old Aug 31, 2004 | 12:47 PM
No more turbo, ALL motor now..
Old Aug 31, 2004 | 09:55 PM
Default Re: Blown Head gasket and stripped block? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">you have to drill the block and heli coil it. </TD></TR></TABLE>
Do i have to take it to the machine shop. Or can I drill it myself. Where can I purchase a heli coil. Need to know ASAP
Old Aug 31, 2004 | 10:21 PM
reactiondc2's Avatar
what kind of motor do you have and what kind of head bolts are you using?reason i'm asking is cause i have seen several people strip out their ls and gsr blocks by using b16 head bolts(slightly shorter than gsr)...if you are using this setup change it when you get your block fixed otherwise it will strip out again in a little while
Old Sep 1, 2004 | 12:40 AM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CATCH DIS HATCH &raquo;</TD></TR><TR><TD CLASS="quote">
Do i have to take it to the machine shop. Or can I drill it myself. Where can I purchase a heli coil. Need to know ASAP </TD></TR></TABLE>
u can do it yourself, but the timesert kit to do it properly is 300 bux, helicoil is a piece of ****, i had one pull on me and had the same problems u do right now.
find a machine shop in your area that uses timeserts, shouldnt cost more than 50 per hole
TIMESERT
http://www.timesert.com
Old Sep 7, 2004 | 09:41 PM
b1ackc1v1c's Avatar
Default Re: Blown Head gasket and stripped block? (Sp00n'd Supra)
how much boost where runnin and which motor??? wonderin cause im about to boost my motor thanks
Old Sep 8, 2004 | 03:37 PM
pip9's Avatar
Default Re: Blown Head gasket and stripped block? (b1ackc1v1c)
timeserts should work well. The kit for a b-series is $300 + shipping from them. I got my custom d-series timeserts kit for $80 from them. I never got to use it though b/c part of the block cracked and broke when i drilled it out.
A friend of mine sent his out to a machine shop had all the holes threaded to the nascar sized arp headstuds. He also had to drill out the holes in the head alittle bigger, but he is having no problems with his engine now. And its stronger than before.
Old Sep 8, 2004 | 04:04 PM
wHOAlly's Avatar
Default Re: Blown Head gasket and stripped block? (pip9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">timeserts should work well. The kit for a b-series is $300 + shipping from them. I got my custom d-series timeserts kit for $80 from them. I never got to use it though b/c part of the block cracked and broke when i drilled it out.
A friend of mine sent his out to a machine shop had all the holes threaded to the nascar sized arp headstuds. He also had to drill out the holes in the head alittle bigger, but he is having no problems with his engine now. And its stronger than before.</TD></TR></TABLE>
find a machine shop local to you that uses them, much cheaper than gettin the kit, they usually charge ~20 bux a hole or so
Old Aug 28, 2005 | 06:41 PM
I got a honda's Avatar
im havin the same prob with one hole in my ls block on the exhaust side....one hole wen i put the bolt in it drops lower then the rest?...im using gsr studs and head....so i dunno maybe the thread is jacked? do i have to use ls bolts??.....machine shop time....
Old Aug 28, 2005 | 07:28 PM
carchitect's Avatar
This concern has been a problem with a lot of aluminum blocks. Honda has a Time-Sert Thread repair kit made especially for this concern. The Head Bolt M11x1.5 thread repair kit (P/N TFC7111) is what you will need to get things handled. For more info visit http://www.timesert.com/html/honda.html
Joe.
Old Aug 28, 2005 | 08:44 PM
mike93eh
Guest
Posts: n/a
i have this same problem on ym d16z6 with one of my studs. i want to go with timeserts but cant find a place to buy them. anyone know what i need for a dseries and where i can buy them and how much they are??
Old Aug 30, 2005 | 05:43 PM
ddustin's Avatar
Default Re: (mike93eh)
Mike93eh, you can get a kit at http://www.threadkits.com/time....html I would call them directly.
I also got a kit for sale...it's for all B-series block for 250 shipped.
Old Sep 4, 2005 | 05:30 PM
mike93eh
Guest
Posts: n/a
Default Re: (ddustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddustin &raquo;</TD></TR><TR><TD CLASS="quote">Mike93eh, you can get a kit at http://www.threadkits.com/time....html I would call them directly.
I also got a kit for sale...it's for all B-series block for 250 shipped. </TD></TR></TABLE>
yes but are those kits the same as the head bolt kits??? remember the threads are down in the block a good 50mm..need long tools.
Old Sep 5, 2005 | 02:43 PM
ddustin's Avatar
It's the master kit I believe...here's a link to a pic of the kit: http://www.we-todd-did-racing....D.jpg
I have used this kit to fix a b18c5 block. Here's an old link w/some pictures of the procedure.... https://honda-tech.com/zerothread?id=921973
Hope that helps
Old Sep 5, 2005 | 02:46 PM
ddustin's Avatar
Oh also, if you decide to order one from them, remember to order the master kit/kit # 7111 (pitch size 11x1.5).
Old Sep 5, 2005 | 02:57 PM
Turbo-charged's Avatar
im running these too. 1/2 inch studs. im running a used block from a parts car i bought...and when i pulled it apart i found one of the holes was sketchy so i just did 1/2 inch in all of them.
Old Sep 5, 2005 | 03:16 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CATCH DIS HATCH &raquo;</TD></TR><TR><TD CLASS="quote">No more turbo, ALL motor now.. </TD></TR></TABLE>
Why would you just give up over one blown headgasket...which is like $130 max to fix? If it's not tuned well enough then get it tuned better and fixed the head gasket. You have to pay to play.
Old Sep 5, 2005 | 04:08 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddustin &raquo;</TD></TR><TR><TD CLASS="quote">It's the master kit I believe...here's a link to a pic of the kit: http://www.we-todd-did-racing....D.jpg
Hope that helps</TD></TR></TABLE>
yes i need that kit but they have it in 11mm x1.50. d series are 10mm x 1.25.
Old Sep 5, 2005 | 04:09 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddustin &raquo;</TD></TR><TR><TD CLASS="quote">Oh also, if you decide to order one from them, remember to order the master kit/kit # 7111 (pitch size 11x1.5).</TD></TR></TABLE>
i have a d series. its 10mm x 1.25 i dont see a kit for that.. shitty
Old Sep 6, 2005 | 09:20 PM
ddustin's Avatar
Oh, I thought you were referring to a B-series Block. Try to call the Thread Kits Co. I know the have a kit for a D-series too. I believe it's cheaper too. Best of luck
michaellong
Jul 30, 2018 07:37 AM
TeamCracka
Feb 16, 2004 06:34 PM
ComputerJLT
Feb 7, 2004 07:10 PM
fiftee_su
10
Feb 5, 2004 07:27 PM
C4wrx
Aug 4, 2002 06:23 PM
