So my head is f*cked; could the block be damaged also?
Well... As some of you know i just bought a 90 si civic with a greddy turbo kit on it and a blown head gasket.
Anyway me and a friend put on a new gasket, reused the bolts, and now the new gasket is fucked so im betting the head is warped.
The game plan now is to buy a new head; new gasket; and ARP STUDS! But before i go throwing money around for that could the block or anything else be fucked up since the beast probably overheated pretty bad?
Also; if anyone has a spare a6 head (bare or whatever) that they'd be willing to donate to an ex honda hater turned honda enthusiest, give me a message
Re: So my head is f*cked; could the block be damaged also? (p0gi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0gi »</TD></TR><TR><TD CLASS="quote">get your head resurfaced. Its usually about $40 or so </TD></TR></TABLE>
or i could get another head for the same price and not have to bother with loosing compresion and shims and all that other mess.
i talked my dad out of resurfacing his pulsar's head since a new one would only cost a bit more and he wouldnt have to deal with all that.
Re: So my head is f*cked; could the block be damaged also? (ComputerJLT)
what are you talking about losing compression and shims? When they resurface they take the minimum amount off to get the head flat, probably not more than .0005. And besides if you buy a used head you should get that resurfaced before you install it.
Re: So my head is f*cked; could the block be damaged also? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">and why are your reusing head bolts?
Re: So my head is f*cked; could the block be damaged also? (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">I reused mine and they've been holding up fine. I reused them because I'm cheap </TD></TR></TABLE>
well your not having a problem, this guy is, so i'd look there first. But then again i wouldn't reuse the bolts
Bolts technically should only be torqued once. Torqueing bolts is actually to ensure they are stretched properly, not tight enough. Regular bolts that are torqued a second time will not meet the proper "stretch" specs. Get some ARP studs, they are reusable.
Re: So my head is f*cked; could the block be damaged also? (RyanCivic2000)
I reused mine because I read posts from people saying they could reuse them and some saying not to. And i didnt want to spend money then on studs.
And now im paying the price.
But anyway; back on topic; could the block or anything else be fucked up if it overheated?
I just stated it since both people asked why he's reusing headstuds. Just saying that it CAN be done. That's all. And yes, the block surface can get warped as well from overheating.
Vice President/CEO
i've got a head from a d16Z6, 2 bent valves, other then that.. its fine if your interested since ur in texas.
over heating could cause a huge problem bro... good luck, get you some arp's learn from your mistakes.
kENNy
kENNy
Re: So my head is f*cked; could the block be damaged also? (kKdARIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">i've got a head from a d16Z6, 2 bent valves, other then that.. its fine if your interested since ur in texas.
kENNy</TD></TR></TABLE>
care to elaborate on what problems it could cause?
Vice President/CEO
Huge problems being what your going through right now... possible damage to the engine.
When you over heat, your oil takes a beating also, so running the car after an over heat could cause more damage unless you get your oil changed.
drumminforev
11
01-04-2007 01:39 PM
Dartanian
06-13-2006 10:40 PM
I8ayellowcrayon
18
01-29-2004 11:42 AM
