Blow by
Old Jun 4, 2004 | 06:21 PM
Charles B.'s Avatar
Default Blow by
What causes blow by besides blown turbo seals? I've been boosting for about 2 months now and I'm already seeing oil in my bov and turbo comp. inlet.
This is a brand new turbo. Tommorow I'm gonna take off my comp. cover What should I look for? TIA.
Modified by CharlesInTurbocharge at 7:42 PM 6/4/2004
Old Jun 4, 2004 | 06:34 PM
BoostedSi's Avatar
Default Re: Blow by (CharlesInTurbocharge)
you could have a kink or bad oil return line setup...
Old Jun 4, 2004 | 06:41 PM
Charles B.'s Avatar
Default Re: Blow by (BoostedSi)
here's my oil return setup
Old Jun 4, 2004 | 06:43 PM
Muckman's Avatar
Moderator in Chief
If the oil return bung in the oil pan is below the oil line it can cause oil to back up in the turbo.
Old Jun 4, 2004 | 06:47 PM
Charles B.'s Avatar
Default Re: Blow by (Muckman)
How can I test to check that? Does my bung not look high enough?
Old Jun 4, 2004 | 07:07 PM
AbaZ's Avatar
It looks a little low, but I've seen lower and ones that were fine
Old Jun 4, 2004 | 07:58 PM
Rod.'s Avatar
Default Re: (AbaZ)
look like it is in the same spot as mine
Old Jun 4, 2004 | 08:03 PM
Charles B.'s Avatar
Default Re: (redturbocivic)
are you having any problems with your setup?
Old Jun 4, 2004 | 11:04 PM
Charles B.'s Avatar
Default Re: (CharlesInTurbocharge)
Ok so the oil in my comp. housing and bov is usually caused by blown seals which is usually caused by backpressure in the oil return, is that right? Is there anything else I should be looking for? I'll try to get pics by tomorrow. Thanks for all the input.
Old Jun 4, 2004 | 11:35 PM
seako_916's Avatar
you might want to do a compression test and see if you have any bad cylinders......i had this prob. and had to re-ring my block.........
Old Jun 5, 2004 | 03:20 AM
Charles B.'s Avatar
Default Re: (seako_916)
yea i plan to do a compression check later today after i get some sleep. what do you mean when you say you had to "re-ring" your block?
Old Jun 6, 2004 | 08:59 PM
seako_916's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CharlesInTurbocharge &raquo;</TD></TR><TR><TD CLASS="quote">yea i plan to do a compression check later today after i get some sleep. what do you mean when you say you had to "re-ring" your block?</TD></TR></TABLE>
i had to remove all the pistons and hone out the cylinders and install new rings on the pistons
Old Jun 6, 2004 | 09:21 PM
Charles B.'s Avatar
yea that's what i thought you meant.
update: i checked my comp. housing and it does not seem to be oil in there; maybe some other substance. i'll inspect further to see what is going on.
Old Jun 6, 2004 | 09:30 PM
Turboteggy's Avatar
A friend of mine once turbo'd his S10. He had such bad blow-by (in the cylinder) that he would pressurize his oil pan, and pop the dipstick out of the tube.
Imagine that pressure going into/up the oil return?
Would make it hard for gravity to pull the oil down out of the turbo.
kallmijonx2
Apr 9, 2010 12:24 PM
DulinDragons
Oct 7, 2009 08:07 PM
MidwestAutoWorks
Sep 7, 2008 05:59 PM
jprelude92
Aug 30, 2008 07:12 AM
Snafu-Si
Jan 22, 2005 10:21 AM
