BOOST GAUGE
Old Nov 13, 2001 | 08:02 AM
97integraLST's Avatar
Default BOOST GAUGE
I have the one on the right.. should i get the one with the Vacuum?
or it doesnt really matter?
Old Nov 13, 2001 | 08:04 AM
Rob03Pro5's Avatar
Default Re: BOOST GAUGE (97integraLST)
I prefer boost gauges with vacuum readings because I'd like to see when I get into boost. But that's just a preference. Also, you can use the vacuum side as a reference for any vacuum or hose related problems.. IE: your car ( a GSR for example) should be at around 20 vac when the car is idling.. if not, something could be wrong.
Old Nov 13, 2001 | 08:24 AM
InfamousDX's Avatar
i have the one with the vacuum and i prefer that personally.
Old Nov 13, 2001 | 08:28 AM
RGAZ's Avatar
New User
I also prefer the vacuum. Helpful with idle and vacuum leak problems.
I also think the Carbon Fiber look is gay, but that's your personal preference. Carbon fiber is a high strength, lightweight material. Why does the gauge face need that? Not ripping on you, just my opinion. If its not gay, its at least rice-boy.
Later.
Old Nov 13, 2001 | 10:03 AM
VTC_CiViC's Avatar
Default Re: BOOST GAUGE (RGAZ)
I also use vaccum, useful for troubleshooting.
Old Nov 13, 2001 | 10:15 AM
Cuz its gonna match the other CF stuff,
Hood and a few accesories
Old Nov 13, 2001 | 10:37 AM
Safir's Avatar
Because the carbon fiber "look" guages do not cost any more than the normal ones, why not get them if you have other carbon fiber elements?
different folks different strokes. the guy didnt ask if you liked CF onyl if you liked VAC
me, i believe vac is just as important to know as boost.
Old Nov 13, 2001 | 11:21 AM
Default Re: BOOST GAUGE (Safir)
Thanks
Old Nov 13, 2001 | 04:53 PM
shamoo's Avatar
Will you make something up for me please?
Yeah, I got the vacuum one. Carbon fiber too. Why not get it? It's cheap, and about 2 bucks more than the non CF ones.
Plus with the vacuum, as someone said, you know when you hit boost. Right now, my car is still being stupid, and I'm trying to stay out of boost. With the vacuum part, I can keep it that way.
Old Nov 13, 2001 | 05:31 PM
Mikex25's Avatar
New User
Default Re: BOOST GAUGE (shamoo)
I would get it just I don't like how the needles and casing are silver if the needles were like red and casing black that would look good.
Old Nov 15, 2001 | 04:33 PM
4dGSR at work's Avatar
Default Re: BOOST GAUGE (Mikex25)
autometer
any of these are far better then the autometer stuff
or this
they are all worth the money and beter then autometer
oh you want about 25 vacuum and boost...???25psi?? or ummm 2 bars
[Modified by 4dGSR at work, 5:34 PM 11/15/2001]
Old Nov 15, 2001 | 06:24 PM
SiRkid's Avatar
Default Re: BOOST GAUGE (4dGSR at work)
autometer =good
Old Nov 15, 2001 | 06:31 PM
shingles's Avatar
curios what makes one boost gauge so much worse than another boost gauge?
Old Nov 16, 2001 | 05:29 AM
Default Re: BOOST GAUGE (shingles)
The Reason I got the CF is to match the HOod that i will be getting
Old Nov 16, 2001 | 06:12 AM
rtype11's Avatar
the engine vacuum at idle will halp you be able to figure fuel for idle, not enough vacuum the computer sees load and adds fuel therefore rich idle, important to monitor when driving.
Old Nov 16, 2001 | 09:23 AM
GSRwBOOST's Avatar
Default Re: BOOST GAUGE (rtype11)
My autometer boost vacume gauge when the car is off, reads just under 0 vacume... and when on.. reads just over -20 on vacume.. SO THE GAUGE IS OFF OR OUT OF CALIBRATION... so far that's the only problem I have from it.. kinda pisses me off because i like things to be exact for readings.. makes me nervous sometimes.. I might switch it out for another one.... like a greddy to match my egt..
Old Nov 16, 2001 | 12:23 PM
Default Re: BOOST GAUGE (GSRwBOOST)
same exact issue
w/ the car off boost /vac. should read 0
MY AUTOMETER GAUGE reads 2??? 2psi!!! that means when i run 7-8 psi it reads 9-10psi!!!
and the vac. reads 2 more then normal!
its off and i dont like it!!!!!
Old Nov 18, 2001 | 08:32 PM
Batoutahell's Avatar
Those boost/EGT gauges look pretty spiffy. Who makes/sells them, and how much?
Old Nov 18, 2001 | 10:18 PM
InfamousDX's Avatar
same exact issue
same thing with my SPI boost gauge. 5 psi when car is off but everything's normal when i start the car. minor details.. nothing's wrong.
Old Nov 19, 2001 | 01:20 AM
MiraiZ's Avatar
Default Re: BOOST GAUGE (InfamousCivic)
autometer sux...this is what I got!
Metric
standard
white faced
colors
[Modified by MiraiZ, 7:21 PM 11/19/2001]
Old Nov 19, 2001 | 04:58 AM
meanteg's Avatar
New User
Default Re: BOOST GAUGE (MiraiZ)
Autometer is good.
Integra LST , your boost gauge is fine, just add a vacuum gauge beside and it will be perfect.
Old Nov 19, 2001 | 05:09 AM
Default Re: BOOST GAUGE (meanteg)
cool, thanks.
grizzled
Jul 9, 2006 09:46 PM
Gsr_Hybrid_theory
Feb 7, 2005 04:38 PM
turbonitrousgsr
Oct 6, 2003 06:54 AM
lildrgn2.0
Feb 25, 2003 07:30 AM
b18tdelsol
May 18, 2002 11:46 AM
