Block Guards
Old May 3, 2003 | 05:57 AM
Patron's Avatar
Default Block Guards
My head gasket is shot. I figured since it's going turbo anyways, I'll have the head off, what kind of block guard should I get? I'm going to just run with an O.E. head gasket. I honestly don't plan on boosting any higher than 10 psi on a t3/t04b.
Old May 3, 2003 | 09:59 AM
AracersGIRL's Avatar
Default Re: Block Guards (ptran13)
the nuformz is a pretty good block guard, a block guard is nothing like sleeves but it does help a little. be careful when on the install because it is very easy to warp the sleeve. like i said the nuformz is good, it has a god amount of holes in it for cooling however many of then are nearly the same.
Old May 3, 2003 | 10:02 AM
boosted hybrid's Avatar
Go with either the nuformez, golden eagle or race engineering. When you install the block guard make sure it drops into place. DO NOT hammer the block guard in if it doesnt fit. Take a dremel with a sanding bit and sand down the block guard till it drops into place. 99% of the reasoning that people experience overheating with blockguards is due to user installation error.
Old May 3, 2003 | 02:20 PM
Howitt's Avatar
Default Re: Block Guards (boosted hybrid)
We have GE one in stock if your interested, just make sure it slids in dont ever hammer it in, your sleeves migth look like Eggs if you do
Old May 3, 2003 | 03:28 PM
dfoxengr's Avatar
Default Re: Block Guards (Howitt)
u dont need one for 10lbs at all...
manicmechanic
19
Dec 18, 2018 10:50 AM
TurboEK9Coupe
Nov 10, 2007 06:03 AM
10SecDSM
Sep 15, 2006 08:11 AM
menkio
Jun 12, 2004 10:37 AM
McFly
Nov 10, 2002 09:10 AM
