which block to use???
Old Nov 24, 2007 | 06:37 PM
killacam661's Avatar
Default which block to use???
i just blew my b16 and im goin ls/vtec or crvtec, which block would be better to go with, ima boost it on 6 or 7 p.s.i. ima get a block guard and the GE vtec kit. how can i make the block safe for boost, what should i buy? im going with the stock b16a head. anyone have any thoughts?
Old Nov 24, 2007 | 06:53 PM
integraRS-T's Avatar
get a b18b1 forged piston/rods and u wont be needing any sleevs if u stay under 400hp
Old Nov 24, 2007 | 06:56 PM
ohh dont get a block guard just in case u would wanna sleevet in the future for high horse power
Old Nov 24, 2007 | 07:59 PM
Integra_drk's Avatar
Default Re: (integraRS-T)
on 6 or 7 psi, any non vtec b series block will be fine assuming its a good tune. Personally I favor the ls block but others would be fine too.
Old Nov 24, 2007 | 10:32 PM
gt35rSI's Avatar
I would use a GSR b18c1 block with your b16 head. It makes a good combo and can handle that amount of boost all day and get you 300whp on the stock block with a reliable tune.
Old Nov 24, 2007 | 11:00 PM
turbolshatch's Avatar
Default Re: which block to use??? (killacam661)
go with the b18b
Old Nov 25, 2007 | 09:37 PM
im going witha b18a1 block.
so which pistons should i get and on what rods?
remember im goin turbo on 7 psi or so which pistons a re good for turbo and i know low compression but which ones?
Old Nov 26, 2007 | 09:53 AM
fireman mike2288's Avatar
Main reason a b18b1 is better is well first of all compression is 9:1 so thats fine and a B20B is just a B18B1 bored out alttle so the cylinder walls are thiner not as sttrong i mean i favor b18b1 since im in middle of boosting one my self, and for pistons i couldnt tell you but for rods go with EAGLE
and really if ur only gonna bost 7psi u dont really needa drop ur compression
Old Nov 26, 2007 | 12:35 PM
pistons to chose;srp,je,cp, wiseco,manley,arias they are all forged and reliable for boost and yeah eagle rods then u can boost ,if u want more then 7 psi
PR8urVtec
Engine Machining & Assembly
21
Dec 14, 2016 04:51 PM
GT500FTW
May 16, 2013 10:27 AM
ys1civicsi
Feb 25, 2007 09:23 AM
f22abuilder
Feb 23, 2006 11:32 AM
Rod.
Sep 12, 2003 10:51 PM
