Which block is better to build for boost?
Old Jan 5, 2003 | 04:38 PM
civicreign's Avatar
Default Which block is better to build for boost?
GSR or LS?? and why. I need some help asap and any info is greatly appreciated.Thanx
Old Jan 5, 2003 | 07:06 PM
BudaKai's Avatar
Default Re: Which block is better to build for boost? (civicreign)
https://honda-tech.com/zeropost?cmd=reply&id=3841359 You tell me... It's all up to how much your looking to spend.
Old Jan 5, 2003 | 07:13 PM
RyanAutry's Avatar
They're the same block... Right?
Old Jan 5, 2003 | 07:21 PM
94TealGSR's Avatar
2 posts, 1 topic, 1 forum...
Old Jan 5, 2003 | 07:23 PM
CzanSOHC's Avatar
Default Re: Which block is better to build for boost? (RyanAutry)
No...different rod ratio, crank...Ect....
Old Jan 5, 2003 | 07:29 PM
RyanAutry's Avatar
Default Re: Which block is better to build for boost? (CzanSOHC)
But he said "What block is better to build for boost"
Aren't you going to change all those if you built.
[Modified by RyanAutry, 8:30 PM 1/5/2003]
Old Jan 5, 2003 | 07:46 PM
CzanSOHC's Avatar
No they are differnt blocks, even if you change out rods, pistons, the ls actually has more cc's then the GSR. but in my opinion the GSr is better, better crank, ALOT better head, but the b18b cost less.
Old Jan 5, 2003 | 09:13 PM
RyanAutry's Avatar
But he said "Which block is better to build for boost?"
But aren't we talking blocks here. Not heads.
Plus we are talking built blocks.
If I build a block I would go with an Eagle Forged, Balanced, polished crank anyways. Plus I'm changing the Rods and pistons.
Now whats different about the blocks? I believe they're the same. . . Right?
If i'm correct. b16, b18, b20 all share the same block, right?
Old Jan 5, 2003 | 09:19 PM
Smashback's Avatar
If you're talking about a bare block, it probably doesn't really matter that much. You need to look at the big picture(s) though. The main thing is, how much money do you have, and how much power do you want. That will help you decide which engine to buy. Any Honda engine will kick *** with sleeves and forged internals...
I went B18B myself because it's the cheapest way I could come up with to get lots of power.
Old Jan 5, 2003 | 09:23 PM
PureTeg420's Avatar
Default Re: Which block is better to build for boost? (Hatchblack)
That's pretty much the best answer you will get. Just work with what you have.
Old Jan 5, 2003 | 10:06 PM
CzanSOHC's Avatar
How can a 1.6 ltr block be the same as a 2.0ltr?
Old Jan 5, 2003 | 10:07 PM
RyanAutry's Avatar
As far as I know, they are.
Different Crank, Rods, and pistons.
Same Block.
DefiantGSR's Avatar
the Si/GSR/type R share the same block. only reason the Si has .2L less is b/c of the crank.
[Modified by DefiantGSR, 7:10 AM 1/6/2003]
Old Jan 5, 2003 | 10:12 PM
RyanAutry's Avatar
Default Re: Which block is better to build for boost? (DefiantGSR)
Doesn't the CRV also share the same block?
Old Jan 5, 2003 | 11:09 PM
rOby's Avatar
decisions
Old Jan 6, 2003 | 12:08 AM
Kwuaymaikrup's Avatar
With the exception of an 84mm piston bore.....yes.
Old Jan 6, 2003 | 12:43 AM
RyanAutry's Avatar
Default Re: Which block is better to build for boost? (Kwuaymaikrup)
Doesn't the CRV also share the same block? With the exception of an 84mm piston bore.....yes.
Thought so.
Old Jan 6, 2003 | 12:50 AM
avividmemory's Avatar
no they arent the all the same...
b18a/b/c and b20 are basically the same more or less
b16 has a smaller deck height also
Old Jan 6, 2003 | 01:25 AM
Foozball26's Avatar
Default Re: Which block is better to build for boost? (SpoolinLS)
this question is all about money. which can you afford to buy up front...go with that
Old Jan 6, 2003 | 01:42 AM
turbohonda's Avatar
the B16 (SI) block has a shorter stroke than the GSR/type R and it also has a 2mm shorter deck height.
the B18A/B and GSR/type R have the same deck height but different stroke cranks
rookshot06
Northern California (Sales)
Sep 9, 2007 04:40 PM
red00si12
May 28, 2007 03:18 PM
tobe1424
Aug 16, 2005 10:11 AM
The_Robster
Oct 30, 2002 02:41 PM
B18CHatch
Oct 18, 2001 03:06 PM
