Big difference between 10lb and 12lb flywheel?
Old Feb 8, 2007 | 05:29 PM
boomersz's Avatar
Default Big difference between 10lb and 12lb flywheel?
Is there a difference between a 10lb and 12lb flywheel?
1Bar GSR's Avatar
Default Re: Big difference between 10lb and 12lb flywheel? (logiT)
About 2lbs... give or take an ounce!
Old Feb 8, 2007 | 05:31 PM
boomersz's Avatar
Default Re: Big difference between 10lb and 12lb flywheel? (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">About 2lbs... give or take an ounce!</TD></TR></TABLE>
Really?
Old Feb 8, 2007 | 05:37 PM
Mugencrxsir1's Avatar
You mean any throttle response difference? Probably not noticeable, unless your well over 450hp were you might feel a slight increase in pull.
Old Feb 8, 2007 | 05:38 PM
boomersz's Avatar
Default Re: Big difference between 10lb and 12lb flywheel? (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">You mean any throttle response difference? Probably not noticeable, unless your well over 450hp were you might feel a slight increase in pull. </TD></TR></TABLE>
Well any difference really.
Old Feb 8, 2007 | 05:57 PM
ExospeedAMcrx's Avatar
2lbs at the flywheel = 2lbs at the wheel. hehe j/k its 2lbs... dont worry about it.
Old Feb 8, 2007 | 06:01 PM
boomersz's Avatar
Default Re: Big difference between 10lb and 12lb flywheel? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">2lbs at the flywheel = 2lbs at the wheel. hehe j/k its 2lbs... dont worry about it.</TD></TR></TABLE>
haha. i mean there's gotta be a reason theres a 2lb difference. i dont see why they would make them that way you know.
Old Feb 8, 2007 | 06:06 PM
why? same company? if its from diff companies, it may just have been their choice and design to make the weight like that.
Old Feb 8, 2007 | 06:13 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">why? same company? if its from diff companies, it may just have been their choice and design to make the weight like that.</TD></TR></TABLE>
yeah same. competition clutch.
Old Feb 8, 2007 | 06:41 PM
vg7z's Avatar
when i turboed my car i didnt even notice going from stock to 12lbs...
Old Feb 8, 2007 | 06:53 PM
boomersz's Avatar
Default Re: (vg7z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">when i turboed my car i didnt even notice going from stock to 12lbs...</TD></TR></TABLE>
haha
Old Feb 8, 2007 | 07:03 PM
Default Re: (logiT)
Wow, I noticed upgrading for my stock flywheel to my ACT 12.5lbs flywheel, and that was on a stock b16 like 4 years ago! I definitely would'nt want a stock flywheel put back into my car now, what tranny are you running? If you have longer gears(ls), then you may not have noticed a difference. Although I'm kinda bias because I've never had my turbo car with a stock flywheel and then upgraded to an aftermarket flywheel; I've always had my ACT flywheel in there. You should feel a difference in your throttle response!
Old Feb 8, 2007 | 08:05 PM
boomersz's Avatar
Default Re: (Mugencrxsir1)
also driveablity
Old Feb 8, 2007 | 08:07 PM
iBrandon's Avatar
Default Re: (logiT)
i have an exedy Flywheel that came with my twin disc...its 7 lbs....Revs alot faster then stock! Never had experience with the 12 or 10 lbs...
Old Feb 8, 2007 | 08:17 PM
SovXietday's Avatar
Dude, thank you for the laugh.
Old Feb 20, 2007 | 03:38 PM
1Bar GSR's Avatar
Default Re: Big difference between 10lb and 12lb flywheel? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Dude, thank you for the laugh. </TD></TR></TABLE>
Glad someone else found it funny! I sure laughed at my own response!
Boostage
Jun 24, 2007 04:08 PM
93eg2james
Dec 19, 2006 04:02 PM
Flr Power
Aug 22, 2004 07:53 AM
yellowbuffalo
Jun 20, 2003 04:45 PM
