big boost on Jdm B16
Old Dec 12, 2003 | 08:46 AM
** OF HAZARD's Avatar
Default big boost on Jdm B16
I want some info on peoples setups! I would like to know anyone's setup running 20 plus pounds. My Friend and I are ready to build his B16. WE have been searching our asses off. We want some real worl experience from you guys. He is gonna run turbo we havent decided for sure what trim etc.etc. But he wants to run 20+ pounds on the street.
Old Dec 12, 2003 | 08:56 AM
BoostedsiR's Avatar
Default Re: big boost on Jdm B16 (****S OF HAZARD)
bore the motor to like 83mm and try to increase the flow of the 1.6 displacement is the key with a b16 if you want big numbers and a big turbo
Old Dec 12, 2003 | 01:29 PM
Default Re: big boost on Jdm B16 (BoostedsiR)
anyone else? Any set-ups tested and tried?
Old Dec 12, 2003 | 02:31 PM
ttt last time
Old Dec 12, 2003 | 02:40 PM
Trak_Day's Avatar
New User
OK first of all, If you run 20psi on a small turbo you won't make alot of power. Secondly if you are setting a goal(or your friend, whoever) go for an ET or WHP amount not PSI. There are way too many things that play into making power at 20psi. Size of turbo probably being the most important.
A few questions you may want to answer so we can help:
Whats your budget?
How much whp? et goal?
Daily driven?
Pump gas? Race Fuel?
Do you have any idea what you are getting yourself into?
Best of luck with it and if you answer those questions i am sure more people will reply. Good luck man, and you will love it
Old Dec 12, 2003 | 03:22 PM
Default Re: (DroppedGSR)
thanks for the info let me elaborate!
1. We want a 11 sec car
2. We want it daily driven
3. Pump gas 85 octane (Iam kidding)
4. We have about 6grand to start off with!
Thanks for the info DroppedGSR
Old Dec 12, 2003 | 04:31 PM
c jackson's Avatar
threes
Default Re: (****S OF HAZARD)
what kind of car is it going in? weight sucks. i hope its a crx
Old Dec 12, 2003 | 04:53 PM
b16ahybrid's Avatar
6k including the cost of the engine? Or 6k for the build up and turbo?
Old Dec 12, 2003 | 07:20 PM
Trak_Day's Avatar
New User
If 6k includes just the money you have to put INTO the motor than you have an OK start but really nothing special.
1. Sleeve bore(83 or 84 mm) deck hone o-ring block- $1000
2. nice rods and CP pistons- $1100
3. custom turbo setup with nice components- $2800
4. Fuel setup- $500
5. clutch, flywheel, LSD- $1200
And that is still not complete but there goes all your money. You are going to need more money if you want that kind of power on pump gas daily driven. It's expensive man, I am 9k deep and my motor doesnt even run yet! and that doesnt include any turbo components, fuel, or tranny!
Good luck and tell your buddy to save UP
Old Dec 13, 2003 | 06:35 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DroppedGSR &raquo;</TD></TR><TR><TD CLASS="quote">If 6k includes just the money you have to put INTO the motor than you have an OK start but really nothing special.
4. Fuel setup- $500
Good luck and tell your buddy to save UP</TD></TR></TABLE>
Your going to need a lot more then $500 into the fuel set-up and tuning. $500 will get you injectors and a fuel pump and maybe a little more
Old Dec 13, 2003 | 07:05 AM
alpha's Avatar
Default Re: big boost on Jdm B16 (** OF HAZARD)
B16a's can't make power
Old Dec 13, 2003 | 08:35 AM
TurboJesse
Guest
Posts: n/a
Default Re: big boost on Jdm B16 (0x64)
how heavy is your car? you can go 11's with a stock block in a lighter chassis rather easily...
Old Dec 13, 2003 | 08:51 AM
AVATAR's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Your going to need a lot more then $500 into the fuel set-up and tuning. $500 will get you injectors and a fuel pump and maybe a little more</TD></TR></TABLE>
$500 should be fine for his goals. . . $285 for 85lb injectors + $90 for Walbro = $375 . . . what else would he need? You could even throw in some -6 or -8 fuel lines and still be under $500.
Old Dec 13, 2003 | 12:30 PM
allablur's Avatar
Default Re: (AVATAR)
i say probe rods
83-84 weisco's or cp pistons
sleeve by rs i believe there is a GB in sponsor pages for 750
crower springs retainers
walbro 255 wired speed has em for 109 shipped maybe cheaper if u ask nice
880 precision injectors importparts has a pretty good buy on em
Fuel rail ur pref
fpr ur choice as well
t3/t4 from cheapturbo is like 550 i think (could go bigger but i think that will do the job)
Kteller8 makes a good 3" mandrel bent really good pricing too
Vtec92Civic makes pretty good ic piping
68-70mm TB i like my str
there are a few peeps selling sst manifolds for like 600 or so
im sure i am miising alot but thats a start ur gonna run short for sure lol i did but its better to go a little over budget and be done then skimp and have something break
Old Dec 13, 2003 | 02:14 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">
$500 should be fine for his goals. . . $285 for 85lb injectors + $90 for Walbro = $375 . . . what else would he need? You could even throw in some -6 or -8 fuel lines and still be under $500.</TD></TR></TABLE>
I wasn't incuding tuning (i.e hondata, aem, etc) into the turbo package of $2800, maybe he was cluding it there....$500 for fuel management (not just fuel delivery) is what i was thinking
Old Dec 13, 2003 | 05:10 PM
Spooled1.6L's Avatar
Im wondering the same thing, I want to hit 400whp off the b16. Can I acheive this with the t3/t4 that came with the drag kit? I like the turbo spools a little slow but that should be more then made up for after the boost is turned up. Is anyone out their hitting 400whp off their b16. And this is in my Ek hatch
I ran 13.8 @ 106 with the worst launch in the world and a 2.5 60ft at 7.5psi
Im thinking Maybe some cames and a better turbo mani, and intake manifold and tunning, oh and 18 or so psi the car should RIP
Old Dec 13, 2003 | 05:16 PM
alpha's Avatar
There are more than a couple B16a's making 400+WHP. Look at the sheet I posted above. My goal is 465whp - 535whp.
thugsbryan
Jan 6, 2013 07:59 AM
b16ajdmrex
May 23, 2009 09:20 AM
MugenSpec-Ny
Mar 27, 2009 01:01 PM
threehonda
Mar 11, 2009 05:37 PM
Damills
Apr 24, 2007 04:26 PM
