Better spark/ignition options
I forgot about that Josh. Yeah the car drove straight for 30 hours from Connecticut to South Texas no issues too after it was 5 years old on the ignition setup
Thanks lightning. There very easy to wire up. Just be sure to follow my instructions because I everyone that doesn't wire it to my directions has issues with no start.
Green wire to A21. This is replacing the input from the originally ICM so I can just cut that wire from the ecu and connect to bypass
Red wire to black/yellow on dizzy: So 3 wires coming together here, Red from module, black/yellow from dizzy, and switched 12v from ign. box? (HI-6 in my case).
Thanks, looks pretty straightforward.
Yes please do a write up for the install. I will be ordering these parts within the week as well
I also replaced my plugs today just because. Surprisingly they were not bkr7e's but rather a 7 heat range vpower
What do you guys think of the wear?
wear looks a little rich but not too bad.
Who is Mr Robot?
about time you broke into the 9s... looks like those new wheels and tires helped a lot, did you ever get the corner weighting done?
I still maintain that for the bulk of turbo Honda setups (sub 500hp) the following combo is all that's needed
accel OEM replacement coil
good set of wires
iridium plugs
the only reason I'm going coil on plug is that the Megasquirt3 Pro can use just the stock crank trigger (my motor/car is OBD2) and run any 3 wire "dumb" coil... like the LS1 coils, which I'll use an upgraded ls1 3 wire coil.
I was going to use my AEM EMS and go cop but you need too much extra bullshit but I've decided the civic is getting an MS3Pro box and I'm tossing my AEM 30-1000 box on my daily driver 1990 F22A1 powered CB7 accord. not sure about upgrading the OEM ignition because I think the coil and such is different on the f series unit as well as it being OBD1
the stock ls1 coils should have enough spark energy for my setup but I'd rather have too much than too little and having to swap things more than once annoys me. the MS3 Pro can run 8 sequential coils straight from the ecu or 12 as wasted spark.. this means no external ignition boxes or special bypasses, no elaborate cam trigger needed either... I can just remove the OEM dizzy and put a cam seal in its place.
(if I remember correctly as far as the trigger goes, I know if I run a 36-1 trigger wheel on the crank then I don't need a cam signal.
good set of wires
iridium plugs
So I'm reading the ignitor bypass basically just takes the load off of the ignitor and the it becomes a switch for the box. Do people commonly have failures otherwise with aftermarket ignitions with the stock ICM?
I guess you are kinda right in that it becomes a sort of switch.
Even with an aftermarket ignition box the icm is still prone to the same failures as without the ignition box. That being heat murders them over and over again
Is that right turbo-ls?
You hit the nail on the head. The icm is completely removed from the system and the bypass module is an interface between the ecu and ignition box so everything works properly. Sorry I'm half asleep and your description is right on.
No it replaces the ignitor. The summit box takes over the role of the oem ignitor. The bypass box is so the ecu thinks the factory ignitor is still in place so everything stays happy. Iirc its also so it cam filter the ecu trigger signal into one the summit box can properly interpret.
I've had one fail on my DD, so it sounds like a good idea.
The job of the igniter (ICM or ignition control module) is to charge the coil commanded by the ECU.
Most people get the igniter HEAT damaged by using too much dwell time. This can often be adjusted in the ECU's calibration.
