what kind of turbo should i use (d-series build)
im building up my dseries motor i was wonder what kinda of turbo i should use i have the greddy kit on there but i want to replace it.
-valves +2omm
-crower stage 2 turbo cam
-cp 9:0:1 pistons(+.020)
-apr head studs
-crower rods
- forged crank (my oem crank cracked)
-new water pump
-new oil pump
-oem gaskets
-race bearing
-edelbrock performer xintake manifold
-lighten flywheel
-clutch master stage 3 clutch
-lighten pulleys
-front mount intercooler
what kind of turbo
i also have greddy emange i didnt hook it up yet should i get somethin else like hondata or should i keep it???
Modified by illogic65 at 2:27 PM 10/30/2006
Modified by illogic65 at 8:12 AM 10/31/2006
Modified by illogic65 at 8:14 AM 10/31/2006
-valves +2omm
-apr head studs
-crower rods
-new water pump
-new oil pump
-oem gaskets
-race bearing
-lighten flywheel
-lighten pulleys
what kind of turbo
i ♥ snails
emanage can work but since u have a built motor why taint your nicely done setup with a tuning program that is not on the same level. Go get ur ecu chipped and run hondata or neptune
There are a lot of other factors that need to determined to decide what turbo would be the best.
What engine is this on?
What are you power goals?
How much psi are you planning on running?
Yes get rid of the emange, and run either hondata, or a chipped ecu with chrome/neptune
That should start you off in the right direction.
ExplicitSpeed
04-06-2004 11:30 PM
ExplicitSpeed
03-08-2004 10:59 PM
