Beginning of A Failure Part 1
UPDATE: 12/15/08
-Pneumatic Fittings & Install
Today i went to work and well, we had nothing to do, so i turned around and came back home.
Decided to be productive so i went and bought the T fitting i needed to run the boost signal lines to the wg and boost controller.
Now back home i needed a vacuum source for the BOV. I drilled the manifold, yes , on the car, with a 11/32" drill bit, wheel bearing grease, and an 1/8" x 28 NPT Tap. After pilot drilling the hole with a smaller bit, i went up to the 11/32" drill bit and then i noticed that the bit was bent, oh wow, great. so i roll it on the garage floor and find out where the bend was, and whap, hammer that bitch straight..
So on to the drilling. I stuffed a rag through the throttle plate opening, coated the drill bit with wheel bearing grease, and drilled away. Ended up working fine, the rag caught all of the aluminum shavings and so did the wheel bearing grease on the drill bit.
Proceeded to tap the hole, coated it in grease as well. end result is as pictured.
and the fitting on the wg
and this is for sale if anyone would like to buy it to help pay for the build. hehe.
snap on graphing meter with 05-06 software. great for diagnosis , wiring pinouts, colors, where to place leads etc.
no i am not planning to move it because i dont think it will break or crack because the heavier object is not mounted on the end of the T, hence the oil switch. i dont think i will have a problem.
whenever i sell this snap on thing ill buy ic piping or some injectors.. i really want the bosch 1000's.
lolz
trying to find the mac series 36 solenoid. wonder if compressed air has it or maybe colliflower can order it. i refuse to pay aem 100 for it or ebay 60 for it when i can just get it close to 30$.
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
wooo finally the install for the scramble button. im in for the install. my 300 dollars worth of an fittings should be coming tomorrow along with my catch can.
