what should i do for fuel
Old Mar 29, 2004 | 07:22 AM
turbo89civicb18hatch's Avatar
Default what should i do for fuel
i have an 89 civic ls turbo, i am curently running 7 psi, for fuel i have stock injectors stock fuel pump, and a jackson racing fmu. i want a better fuel setup because at 7 psi it still leans out. i want to run 10 psi with a better fuel managment setup. what should i do.
Old Mar 29, 2004 | 07:45 AM
b16ahybrid's Avatar
Default Re: what should i do for fuel (turbo89civicb18hatch)
Whats your budget?
My buddy would lean out above 5psi using a fmu and stock pump (done on a dyno) so 7psi is asking for it.
You can do a wide aray of things, it all depends on how much you want to spend
Old Mar 29, 2004 | 07:48 AM
JdM_y0's Avatar
u can do urberdata or hondata. i would say urberdata if u have no money and hondata if u want that bling bling name
Old Mar 29, 2004 | 07:49 AM
i cant afford hondata, i could eventualy get an safc with dsm injectors. i would like to spend less than that though
Old Mar 29, 2004 | 07:50 AM
Default Re: (bluep3)
how do i do urberdata
Old Mar 29, 2004 | 08:22 AM
b16ahybrid's Avatar
Default Re: (turbo89civicb18hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo89civicb18hatch &raquo;</TD></TR><TR><TD CLASS="quote">how do i do urberdata </TD></TR></TABLE>
Kinda like hondata, you need to get the software from the site, and proms from an electronics store.
Not sure on the whole set-up, but like hondata you will need larger injectors.
For now I would at least recomend a better fuel pump (walbro 255lph) if you plan to keep runing 7psi with a fmu.
One you get that pump it will buy you a little time so you can save up for your choice of fuel management
2SlowDC
Jun 16, 2004 10:15 PM
Bictorious
Feb 16, 2004 09:36 AM
Bictorious
Jan 27, 2004 12:18 PM
BoostedSOHC
Apr 11, 2003 10:46 PM
BoostedSOHC
Apr 11, 2003 02:49 PM
