bad pump or fuel regulator?
Old Jan 24, 2007 | 04:30 PM
staticpage's Avatar
Default bad pump or fuel regulator?
So I have a big problem I’m running a h22 on 440’s. it’s been running fine for about 4 weeks at 7psi. I have a no name fuel regulator, stock fuel pump.
The problem started one day out of the blue, right after I started it. The car idles fine, but has no power and the turbo mani is getting red hot. So I thought off the top off my head that that means a lean A/F. so I look at the fuel pressure gauge on the regulator, its reading all crazy flickering from 42psi to 55psi. the line that goes from the rail to the regulator is fuel injector hose. If you hold that line you can feel the hose pulsating .
So can any one tell me if that is a bad pump or fuel regulator? I thought when a pump went it just stopped? And went a fuel regulator went it just stuck open.
Help please
Old Jan 24, 2007 | 06:41 PM
JSPECSIR's Avatar
Default Re: bad pump or fuel regulator? (staticpage)
disconnect the vaccum source to the regulator and see if the pulsation stops. also if its a cheap regulator its possible the boost coming into the vaccum line damaged it in some way. idunno just my .02
Old Jan 24, 2007 | 11:29 PM
Darrell Bs 10SecEG's Avatar
The regulator might of got something stuck in it.It happened to me 3 times.So try another regultor or FMU.Take off the fuel lines and blow them out with an air hose.THat should work.
Old Jan 24, 2007 | 11:34 PM
One more thing,This other thing happened to me a few years ago,The regulator on the fuel ril started leaking gas into the motor so be careful.Drain your oil and see if U see gas coming out of the oil pan and smell it.If it does,Put new oil in it and run it for 15 minutes,Then drain it,Change the oil filter and add new oil again cause if U dont do this exactly like I say,U will scratch your main and rod bearings up.But make sure when U first take off the regulatr,Try to blow through the vacuume side and if air comes out through the gas return,Then your regulator is blown.Good luck
Old Jan 25, 2007 | 07:25 AM
staticpage's Avatar
JSPECSIR thats the first think i tried thanks.
im running uberdata so no fmu. I'll try a different FPR.
Old Jan 30, 2007 | 01:21 AM
Your fuel filter might be clogged.Try another one.
solattack77
Mar 30, 2011 11:38 AM
B18 CYA
Jul 7, 2006 04:11 PM
B18 CYA
Jul 7, 2006 03:52 PM
oneslowcivic
Sep 19, 2003 08:02 PM
18gsir
Jul 23, 2003 12:26 AM
