Fuel Pressure Issues
Old Mar 29, 2011 | 08:43 PM
solattack77's Avatar
Default Fuel Pressure Issues
We just started my new turbo motor last weekend and we are having fuel pressure issues. We flared the stock line into a -6 into an earl's in-line, then up to an Aeromotive A1000 fpr. The gauge is a matching aeromotive showing 15 psi of fuel, then we switched to a blox gauge and it showed the same. Pump is a walbro 255lph. Not quite sure what is going on. Any suggestions would be greatly helpful. Thank in advance
Old Mar 29, 2011 | 09:48 PM
Tony the Tiger's Avatar
Default Re: Fuel Pressure Issues
Do you have an internal leak at the fuel pump? A hose popped off, loose clamp, etc.. at the pump exit/outlet can do that.
Are you also experienced with fuel systems in general? Many cases, I have seen folks accidentally hooking up the regulator at the wrong ports, and in turn, it gives some totally wacked up fuel pressure readings.
Old Mar 29, 2011 | 09:49 PM
i havent found any leaks anywhere. Not a lot but i have some. I have the feed on the right port, to the rail on the left port and the return coming off the other side of the rail. even when my tuner starting messing with the adjustment on top of the fpr, it didnt move
Old Mar 30, 2011 | 07:51 AM
92redhatch's Avatar
Crimp the return line if the pressure goes up it's the regulator. If it doesn't your issue is the hose on the walbro is leaking or broken or popped off. I had then same issue last week with my dual walbro setup and my issue was a leaky hose. It had a gash in it and my fuel pressure gauge said 10psi
Old Mar 30, 2011 | 11:38 AM
i will try that next time i go to the car
scuffywin
Jun 5, 2007 04:15 PM
hybrid_vtec
Aug 5, 2004 10:03 AM
gsrvtechatch93
Mar 12, 2004 04:33 AM
boostaholic
Jun 30, 2002 07:25 PM
JM Performance
Dec 20, 2001 03:51 PM
