bad boost lag? caused by no 02 sensor?
Old Apr 30, 2010 | 06:55 AM
turboman2.2's Avatar
Default bad boost lag? caused by no 02 sensor?
i have ls vtec fully built untuned, i am trying to test out the turbo befor i tune, and it boost 5 psi at around 4000rpm.. isnt that a little bit late for a 60/63 trim precision turbo?.... iam thinking its because the car is running too rich because no o2 sensor...... but i could be wrong.. could the O2 sensor cause the turbo not to spool right because its just shooting unburnt gas into the turbine?????
Old Apr 30, 2010 | 06:58 AM
kyden's Avatar
Default Re: bad boost lag? caused by no 02 sensor?
lack of o2 sensor has nothing to do with it. when you go WOT it ignores it anyway. do you have any boost leaks?
Old Apr 30, 2010 | 07:25 AM
i dont think so i tightend all the couplers with t clamps pretty good
Old Apr 30, 2010 | 01:44 PM
turbo-2nr's Avatar
TUNE IT BEFOR YOU GET ON IT
Old Apr 30, 2010 | 03:12 PM
keving85's Avatar
Agree
Old May 1, 2010 | 05:59 PM
well i got a pretty good exhast leak from the wastegate flange
Old May 2, 2010 | 07:34 AM
HiProfile's Avatar
[QUOTE=turboman2.2;42336322]i have ls vtec fully built untuned[QUOTE]
No tune = super lean leading to boost. You are probably detonating a thunderstorm, ruining your pistons and valves, not to mention not making any power. That is one reason why it's spooling late.
NExt, if you have *ANY* leak in the charge pipes or the exhaust (before the turbo), it will spool very late. If your exhaust is leaking enough where dead exhaust gasses are being sucked into the turbo's inlet, you're spooling even later because you can't burn dead exhaust gas. Read up on Direct Exhaust Injection and why it's not helpful.
Old May 2, 2010 | 09:36 AM
bemanuel's Avatar
Originally Posted by lookout22
when you let off the gas the valve opens and the waste gate will release.
I think you are kind of confusing a wastegate with a BOV.
A wastegate opens to control boost, which means, once desired boost pressure is obtained it opens, bypassing exhaust gases from the turbine to the ground or to the downpipe. which in turn slows down the turbine keeping a constant boost pressure on the compressor side.
However, any exhaust leak pre-turbine will cause spool issues.
Old May 2, 2010 | 02:43 PM
dpetro1's Avatar
TUNE IT BEFORE YOU GET ON IT
x2
/thread
Old May 2, 2010 | 03:45 PM
JDM94HATCH's Avatar
lol......
Old May 3, 2010 | 02:14 PM
lookout22's Avatar
yea yea im a douche. it was late and i was stoned. and when you let off the gas the waste gate closes .. i dont know what i was thinking...
mrbsponge
Mar 3, 2011 03:26 AM
motormike40
Oct 22, 2006 03:54 PM
5STAR3
Aug 10, 2003 10:10 AM
WhoNeedsVtec
Feb 25, 2003 11:29 PM
bodydropranger
Jun 14, 2002 06:28 AM
