replacement O2 sensor for PLX M300?????? local??
Old Jun 18, 2005 | 09:43 AM
mrbsponge's Avatar
Default replacement O2 sensor for PLX M300?????? local??
does anyine know the model car i need to ask for when buying a 5 wire wideband to replace theo ne that came with my PLX model??
i know someone mentioned a VW, LMU or something but i have no idea what that is or what year to ask for it from, i just dont want to go hacking up plugs and sensors any more!
Old Jun 18, 2005 | 03:01 PM
adseguy's Avatar
Default Re: replacement O2 sensor for PLX M300?????? local?? (mrbsponge)
interested as well. I think mine just gave out today.
How did you knows your died? I was tuning with Crome in my car and the AF very everywhere cause of the basemap I created.....then all it said was LEAN in boost. I fucked around and finally just used my good ol Uberdata bin and still the same. Any time I get into boost now it says LEAN...which for it to say LEAN while in boost I would have a blown motor already and that's not the case. Just want to know how your gave.....I had mine for 8 months
Old Jun 18, 2005 | 09:41 PM
mrbsponge's Avatar
mine will come on......read correctly for about 30 seconds after warm up, and then slowly escalate till it says LEAN, and then it will read every now and then, also it was readin like 15:1 in boost, and i KNOW it wasnt
Old Jun 18, 2005 | 11:19 PM
adseguy's Avatar
Default Re: (mrbsponge)
hmmm kinda like me......so you think it's our sensors or the box itself. What's so strange is this was all of a sudden. I'm callin PLX tomorrow and see about waranty or where to get a replacment FAST . Report back if you find somethin mrbsponge
Old Jun 18, 2005 | 11:20 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (adseguy)
cant you recalibrate the sensor?
Old Jun 18, 2005 | 11:27 PM
adseguy's Avatar
Default Re: (wantboost)
not that I know of
Old Jun 19, 2005 | 04:03 AM
B6tPoweredMx3's Avatar
yea mines doing the same thing. kinda pisses me off since ive only got about 500 miles on the o2 sesnor.
Old Jun 19, 2005 | 05:40 AM
PyroProblem's Avatar
Default Re: (B6tPoweredMx3)
If you guys need O2 sensor replacements and PLX wont help you out, I can get you replacements @ my work for prolly a lot less than if you go in off the street as a regular customer using my employee discount. I forget the actual p/n but it is for newer VW's.
I priced one when I recieved my PLX and I want to say they were about $50. I couldnt believe how cheap they were!
BTW, I think its supposed to calibrate itself everytime you re-start your car or turn the unit on.
Ill get you guys more info when I go to work on Monday
Old Jun 19, 2005 | 07:28 AM
seen4ever's Avatar
Default Re: (PyroProblem)
Go to a Volkswagon dealership and ask for a o2 sensor off any 1.8t engine. So just say a 2001 Jetta 1.8t. They will bring out the exact same sensor you have in your car.
its the VW 7057 sensor, the exact part number is on the sensor itself, you will see VW and a list of numbers with the end numbers being 7057.
or you can just go here:
https://www.1stvwparts.com/partscat.html
part number is: 021-906-262-B
Its a volkswagon part number.
Old Jun 19, 2005 | 09:55 AM
ComputerJLT's Avatar
Default Re: (seen4ever)
1st vw = best place by far
i've ordered 3 sensors from them
pulled a proffit on all three too :-p
Old Jun 19, 2005 | 09:59 AM
TypeR0186's Avatar
Default Re: (ComputerJLT)
Similiar with zeitronix wb o2? I know they can use VW o2 sensors, but not sure if this is the exact same one?
Old Jun 19, 2005 | 11:06 AM
adseguy's Avatar
Thank you guys soo much. You guys Rock!!
Old Jun 19, 2005 | 11:17 AM
project dc2's Avatar
Default Re: (TypeR0186)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0186 &raquo;</TD></TR><TR><TD CLASS="quote">Similiar with zeitronix wb o2? I know they can use VW o2 sensors, but not sure if this is the exact same one?</TD></TR></TABLE>
same one.
Old Jun 19, 2005 | 01:57 PM
seen4ever's Avatar
Default Re: (project dc2)
Innovative, PLX, Techedge, Zeitronix all use the exact same sensor which can be purchased from what i linked above.
Or you can go through PLX directly and pay 85 bucks.
Old Jun 19, 2005 | 02:35 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">Go to a Volkswagon dealership and ask for a o2 sensor off any 1.8t engine. So just say a 2001 Jetta 1.8t. They will bring out the exact same sensor you have in your car.
Thank you.
Old Jun 23, 2005 | 06:02 AM
adseguy's Avatar
Default Re: (Jim Truett)
Well, just to update. I got the wideband for $38 without shippping from that website above and it works like a charm now. I tried to clean the other one with brake cleaner and water, but to no avail. Thanks again to seen4ever for the great link
Old Jun 23, 2005 | 11:58 AM
B16Civic93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Well, just to update. I got the wideband for $38 without shippping from that website above and it works like a charm now. I tried to clean the other one with brake cleaner and water, but to no avail. Thanks again to seen4ever for the great link </TD></TR></TABLE>
which one exatly did you purchase off htat site? there are like 8 of them but they are most likely the same ones, just for different vehicles for some reason. i just didnt know if they had different thread patterns or a different type of sensor all together. so which one did you get exactly.
Old Jun 23, 2005 | 12:34 PM
adseguy's Avatar
Default Re: (B16Civic93)
they are all the same part number and all the same price so I assume that it's the same sensor. I called because I needed 2 day shipping since I gotta tune with it this weekend.
Old Jun 23, 2005 | 01:07 PM
mrbsponge's Avatar
thanks guys SERIOUSLY
i went to autoparts stor "brand X" and they said 179.oo for the VW o2
and yes i ordered it form that VW site for the same 38 bucks, DAMN thats hot!!!!!
Old Jun 23, 2005 | 02:09 PM
ITSME4G63's Avatar
thank you for the information, i will pass it on
Old Jan 9, 2008 | 05:41 PM
Tippyman's Avatar
Default Re: (ITSME4G63)
BUMP back from the dead. I just bought a NGK AFX wideband and wanna know if the VW sensor will work.
Anyone know of a cheap sensor that will fit the AFX if not the dub sensor?
Old Jan 9, 2008 | 09:34 PM
ghostskinner's Avatar
Default Re: (Tippyman)
wanna know if this sensor will work with the aem wideband as well
Old Jan 10, 2008 | 05:49 AM
sp00led's Avatar
Default Re: (ghostskinner)
damn 3yr old post. Those sensors are not $38 anymore lol. That site is selling them for $77.71 plus shipping. Anyone come across a cheaper site I can bookmark. I paid $70 from a guy that is an inovative dealer but figured I could find the cheaper through VW.
Old Jan 10, 2008 | 07:04 AM
SOHC_MShue's Avatar
Default Re: (sp00led)
last time i went to vw the price was way up there. I remember them being cheaper before. Now they are way more than what innovate charges for replacements.
Old Jan 10, 2008 | 09:24 AM
seen4ever's Avatar
Default Re: (SOHC_MShue)
haha, i saw this thread and thought, how the hell does mrbsponge not know where to get that sensor. definately not 38 bucks anymore, but they went up over a year ago. 77 bucks still isn't bad when PLX and others have been selling for 80+ for years now.
this won't plug and play with AEM as the AEM has a special calibrated sensor, well atleast the last time I held a UEGO from them, which was 3+years ago. I'd think the NGK would use a NGK sensor, but if its a bosch sensor, its most likely the LSU2.
