help 4 psi of boost with the o2 sensor pluged in
Old Jun 14, 2002 | 02:50 AM
bodydropranger's Avatar
Default help 4 psi of boost with the o2 sensor pluged in
why can i only get 4 psi of boost with the o2 sensor plugged in but when i unplug all but the signal wire i can pull 10 psi the air fuel gauge says it is not too lean
b18c in 92 hatch back
Old Jun 14, 2002 | 03:20 AM
inspyral's Avatar
Default Re: help 4 psi of boost with the o2 sensor pluged in (bodydropranger)
I'm not sure I understand your question, but there shouldn't be any direct correlation between your O2 sensor and the amount of boost your tuebo produces...
Old Jun 14, 2002 | 04:28 AM
Default Re: help 4 psi of boost with the o2 sensor pluged in (inspyral)
that is what i thought also but when it is plugged in it seems like it changes something on the computer
Old Jun 14, 2002 | 06:28 AM
dbman96's Avatar
New User
Because when you take out your O2 sensor, the computer goes into "oh **** something's wrong" mode and dumps in too much fuel, which in your case is "just enough" fuel.
motormike40
Oct 22, 2006 03:54 PM
Perfectionist
Oct 8, 2006 02:00 PM
5STAR3
Aug 10, 2003 10:10 AM
WhoNeedsVtec
Feb 25, 2003 11:29 PM
HondaCutter
Nov 26, 2002 10:47 AM
