Dummy O2 Sensor with Rev Hard Turbo Kit
Hey, My friend has a rev hard kit on his b16a2, and he just got hondata and got it tuned, and he still has a CEL, The O2 sensor is reading boost in the downpipe, one of the shops he goes to told him to try and find a dummy O2 sensor, they are common for domestic but i havent seen any for Honda's. Has anyone had any experince with this? If so where can he get one from? Also if the dummy 02 sensor wont work, what else should/could he try? Thanks alot.
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (WhoNeedsVtec)
Wow, an o2 sensor that reads boost!! Pretty cool, how much boost is he running in the downpipe?
I'm going to start using vdub o2 sensors in my car if they read boost. I have no idea how much boost I'm running on the exhaust side
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (Hatchblack)
so do they make a 3 bar o2 sensor cuz I run 15 psi.
[Modified by foozball-26, 8:49 PM 2/23/2003]
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (tony1)
He's asking for me and what he meant to say was since you needed to be such a inconsiderate ***** was my O2 sensor is obviously reading something wrong so ANY HELP NO SMART ANSWERS FROM **** WHO HAVE NO LIFE WOULD HELP thanks have a nice day
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (00SIBOOST)
First off the question made no sense and I dont think anyone reading it understands what your asking. Since the problem is with your car, why dont you restate it? What the hell is a dummy o2 and they dont read boost so maybe that can answer part of your question.
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (ninesecrx)
ALRIGHT HERE IT IS my car is throwing CEL 41 has been for a while now even after tuning my local shop told me there are so called summy o2 sensors AKA a o2 simulator i was wondering IF these even exist or what else i could do to find one or Mcgiver one to get the dreaded yellow light to go away thanks again
When I was OBDII I had to run an O2 Sensor Simulator on the secondary O2S with the test pipe to avoid limp mode. Worked pretty damn good for me.
ECG sells them. PM zip here on the board. He should be able to give you the info you need.
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (swrdply400mrelay)
so what extacly are his options here? I really didnt think the question was that difficult to understand, on the first post i made. oh and this right dub's o2 sensor do read boost, buy one
Also, I'd like to hear a little more about this o2 sensor that reads boost! It seems that you don't have a clue...
CEL - 41 - Primary Oxygen Sensor - Heater circuit malfunction....Can you exlpain this to me? How do I go about fixing it?
edit**I searched and didnt find much on this specific code. Thanks for the help.
[Modified by WhoNeedsVtec, 10:13 PM 2/25/2003]
Here a link for a o2 simhttp://userwww.sfsu.edu/~ecg/o2sim.htm
but like someone else said its for secondary o2 so you can run a test pipe.
I think you should try swaping your primary o2 sensor for a known good one and see if it fixes the problem. I don't know if you have done that yet, but thats what I would probably do first.
Maybe you could take it to someone with a scanner ie. dealer (i could be wrong but...)It will narrow down the problem. (if thats possible) I am assuming you did the paper clip trick to get your error code. Other than that I dunno - sorry I couldn't be of more help to ya
Obviously he is probably confusing the MAP sensor for seeing boost. Instead of baging him for this, since it seems we all know what a Code 41 is, why don't we help him? I'm glad we have a lot of bandwagon jumpers. Yes blowing up was not the most mature thing to do, but why don't we see what we can do. Afterall I thought that's what this board was about, learning. You can't expect everyone to come in here being experts. Anyway's, a dummy O2 sensor will work for secondary only. Test the voltage of the primary O2. Hope you don't have to replace it, they aren't very cheap. Call autoathority and see what they say. Have fun and don't get frustrated by some of the people on here. We aren't all bad.
Later.
Later.
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (Mr Milano)
thanks for the kind remark Mr Milano, I wish there were more people on here that would help instead of bashing like you say, I am doing my best to learn, and just remember you guys started somewhere also. thanks again
Code 41 is: Open or short in Primary O2 sensor heater circuit, defective Primary O2 sensor heater circuit. An ECG O2 simulator, or dummy O2 sensor is for your secondary O2 sensor; it makes your ECU think you're using a cat. If you use it on your primary, your car will run crappy.
Re: Dummy O2 Sensor with Rev Hard Turbo Kit (DeepSi)
thanks for all the help guys sorry for blowing up at you guys but with my car if its not one problem its another and well after tonight i have a bigger worry than o2 sensor somewhere in my car there is a huge oil leak and well basically drained all the oil from my car( Luckily we had found the leak and got it to the local shop before it was dry) will keep you guys posted and i have nt replaced the primary yet hope i dont have to the car is fully tuned and i must say autothority did a very good job so me running rich and causing it could not be it not to mention my car goes in for inspection within the next month thanks again
Turbo'dMex-A-Keen
06-24-2003 07:18 PM
