B20V TypeR cams?
Old Jul 29, 2014 | 01:27 PM
Project_SOHC_EX's Avatar
Default B20V TypeR cams?
Setup b20v high compresscompression fully built gsr head typer cams .5mm over on the valve TypeR cams Turned the motor cams don't spin as free as they should...I'm thinking 1)I haven't done the valve adjustment and 2) cam caps may need to be filed a bit they were mismatched between a set of b16s....need help
Old Jul 29, 2014 | 02:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: B20V TypeR cams?
Um NA or turbo motor?
me thinks wrong forum.
not having the valve lash set right could be part of the issue but your bigger issue is mismatched cam caps... each head and cap are line honed as a set so the journals are the proper size. change the cap and the journal diameter and shape change.
you probably need to pull the cams out and check for any signs of wear and scoring on the cam and head journals.
you then need to put the caps back on with no cams, torque to p
spec, and measure the journal diameter and if the journal bore isn't out of round
Old Jul 29, 2014 | 02:48 PM
NotARaCist's Avatar
I never narc'd on nobody!
You're running mismatched cam caps. That's your problem. Time to start hoping you didn't score your cams to ****.
Old Jul 29, 2014 | 04:48 PM
I have not run the car yet and 4 the record it is na looking to go f.i....I was told they can filed to size should I have my machine shop hone the caps to size or...??? I'm stuck
Old Jul 29, 2014 | 05:05 PM
NotARaCist's Avatar
It's a little bit more complicated than "filing" them. OK, I lied, it's a LOT more complicated than just filing them down. Your head and caps need to be line honed. This generally involves bolting them down, torqued to spec, then using a honing tool to make sure they are perfectly mated.
Old Jul 29, 2014 | 05:11 PM
wantboost's Avatar
Who is Mr Robot?
Yea it's nothing like "filing"
it's a highly involved precision process that takes hours to do right and isn't cheap.
Old Jul 29, 2014 | 05:52 PM
NotARaCist's Avatar
And one slight mistake can completely ruin the head.
Old Jul 31, 2014 | 03:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
You might want to pull the head and have a real machine shop line bore the cam caps! you can't use mismatched cam caps!! why didn't you at least do the valve lash before turning the motor?
Old Aug 1, 2014 | 02:20 PM
wantboost's Avatar
Who is Mr Robot?
this whole scenario has "cluster ****" written all over it
Old Aug 1, 2014 | 05:40 PM
turbohatch96y7's Avatar
to be fair you cant really do the valve lash without putting on the timing belt and turning the motor..
op is a dummy for usuing mismatched cam caps
Old Aug 2, 2014 | 03:17 PM
2kdrift's Avatar
Id prolly just get a new head no idea how much line boring cost tho. But u better hope you didnt mess up those cams there prolly worth more then the head itself. As everyone else said you need to use original caps there line bored from the factory no 2 head have the exact same caps
Old Aug 2, 2014 | 03:56 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its not the end of the world pull the head send it to a real machine shop have them line bore the caps and hot tank it and have it fresh and ready and reinstall the head properly.
Old Aug 2, 2014 | 03:58 PM
NotARaCist's Avatar
And hope you didn't score the **** out of your cam journals.
speedy8281
Engine Management and Tuning
Oct 5, 2010 10:29 PM
rdeezy78
Jan 11, 2006 12:05 PM
skunk2finatic
Dec 19, 2004 04:28 PM
bluesi00
Mar 23, 2004 10:32 PM
tuan...
Jan 27, 2004 07:52 PM
