B20B
Old Feb 1, 2005 | 04:17 PM
91DroppedHatch's Avatar
Default B20B
Hey im stuck between the b20b turbo with an ls head idea, or the crvtec turbo idea. So what I wanna know is, is it worth all the trouble adding a vtec head? Or would it just be alot easier to build up the block and the ls head for turbo, and boosting the hell out of it? Either way there both gunna be built up, so i just need some advice, my friends going to have an ls/vtec turbo, and I dunno if he will have more power than i will so i need some opinions, thanx.
Old Feb 1, 2005 | 04:46 PM
Default Re: B20B (91DroppedHatch)
anyone
Old Feb 1, 2005 | 05:08 PM
dornon13's Avatar
prolly not worth it...but it all depends...id spend the money somewhere else...like towards traction
Old Feb 1, 2005 | 05:48 PM
Blue98Ex's Avatar
Default Re: B20B (dornon13)
The vtec is definitly worth it in my opinion. U should get more hp out of a built vtec head, then out of a built non-vtec head for sure. My .02 cents
Old Feb 1, 2005 | 06:46 PM
Ef-er's Avatar
i'd build the block, then slap a vtec head on, vtec head flow way better
all depends how much hp u looking to get right?
Old Feb 1, 2005 | 07:56 PM
Vxhatch's Avatar
Default Re: B20B (ChineseGuy)
as far as block choice.. I'd consider using a B18a/b block for the sole reason of better sleeves.. the B20 cylinder walls are not as strong as the B18a/b, but you do get the extra .2 liters. basically if you are planing on build the block it really doesnt matter, If i were in your situation I'd get the B20 and resleeve it with a vtec head, but if not ls/vtec turbo im definatly not trying to persuade you in either direction, just make sure you do quite a bit of research so you dont have to kick yourself in the butt later... haha whatever you do have fun with it!! either way you'll kill a V8
Old Feb 2, 2005 | 09:02 AM
Default Re: B20B (Vxhatch)
ya im going to resleeve it, also would it be easier to buy that golden eagle ls/vtec kit?
Old Feb 2, 2005 | 10:34 AM
dornon13's Avatar
yeah but you might want to use a different head gasket...im not sure how strong those are considering you are going high hp
Old Feb 2, 2005 | 04:27 PM
which headgasket do u suggest?
Old Feb 2, 2005 | 04:39 PM
rtmiami's Avatar
Default Re: (91DroppedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DroppedHatch &raquo;</TD></TR><TR><TD CLASS="quote">which headgasket do u suggest?</TD></TR></TABLE>
Cometic. Used them before with no problems
slowboyy06
Aug 18, 2009 12:39 PM
swappedcx
Sep 4, 2006 05:10 AM
94_CRVtec
Jan 27, 2005 06:27 PM
streetlvlhatch
Dec 4, 2003 01:27 AM
VASlowTec
Oct 22, 2003 05:35 AM
