B18c White smoke from valve cover HELP!!!
#26
Re: B18c White smoke from valve cover HELP!!!
Old thread....
Just saw this thread though. Freaking ridiculous!! I can't believe how some guys beat on their rides badly.
Bean- You need to do a compression/leakdown test. It still might not tell you everything, but it's a start. And also need to start a thread and list in detail your issues.
#27
Befor you blow your motor completely, pull the head off, do a leak down test for ***** n giggles, after that drop the oil pan, pull the pistons out my bet is that you have a cracked piston. I have seen it happen alot where the piston cracks right at the ring lands, huge contributer to blowby, + cause for white smoke coming out of the Vc and the exhaust. Happens when you boost a motor that isnt built for it. Fix* - new head gasket new pistons and rings. Save your motor befor you spin a rod, or shoot somthing out the block.
NeXtLeVeL_TyPe_R
05-16-2002 06:19 PM
