b18a1 build in progress
Old Feb 27, 2013 | 07:54 PM
  #51
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: b18a1 build in progress
i dont think 6k is enough to be honest, you have to remember a little thing called a transmission that will need to be serviced as well and axles to go with it
Old Feb 27, 2013 | 08:09 PM
  #52
OBRJosh's Avatar
s
Old Feb 27, 2013 | 08:17 PM
  #53
OBRJosh's Avatar
Originally Posted by wantboost
I wouldn't run a 6262 or precision anything, they've been having problems with compressor wheel flex at high boost pressures, the hub twists and puts the blades into the compressor housing, destroying the turbo... and whenever someone sends in a unit like that precision always says oil contamination so the warranty is void, etc,
Stay far away from precision, pick a genuine Garrett based unit or have TheShodan build one for you.
Besides precision refuses to ever have compressor maps made for their turbos, they said it was a waste of money, when compressor maps are the proper way to size a turbo,,, you can just advertise that a turbo will support XXX HP without having any way to show bow it flows at what pressure level/air flow,
Stick with a reputable company like Garrett or like I said, TheShodan can make you anything you want... with an amazing warranty and customer support.
But it sounds like you're just pipe dreaming and don't really know what it takes to make 600hp and pug it to the ground, you'll need a good suspension setup as well as brakes and a good set of tires
And stay away from anything china/eBay
Were do you guys come up with this stuff? smh..I personally know 5 Honda's running 6262's and a few 6266 cars here in TX Running @ San Antonio raceway running 10s making 600whp
Old Feb 27, 2013 | 09:23 PM
  #54
stowne78's Avatar
Whelp Benson is $1200 plus shipping, and it will be made special to your pistons....I don't think golden eagle is any better than Benson...
Old Feb 28, 2013 | 01:22 AM
  #55
wantboost's Avatar
Who is Mr Robot?
Most of the units do well, however the ones that fail, that's what we've noticed. Maybe it was only an issue with the earlier units that somehow are still being sold from sitting on a shelf somewhere
And yes sleeving is expensive... what were you expecting?
Old Feb 28, 2013 | 03:41 AM
  #56
srqslop's Avatar
I know sleeving is expensive i have built motors before. 1500 fir a sleeved block is cheap. I'm used to about twice that.
Old Feb 28, 2013 | 05:52 AM
  #57
stowne78's Avatar
^^^YIKES^^^
Old Feb 28, 2013 | 12:22 PM
  #58
srqslop's Avatar
But I'm used to building 8's not 4's lol so twice as many sleeves lol
Old Feb 28, 2013 | 03:33 PM
  #59
srqslop's Avatar
Head came in today!!
Old Feb 28, 2013 | 03:36 PM
  #60
Idk about anyone else but I can't see the pics
Old Feb 28, 2013 | 03:38 PM
  #61
Builda'Teg_92's Avatar
  #62
srqslop's Avatar
Idk know why but i can't see what pics i posted.
Old Feb 28, 2013 | 03:39 PM
  #63
grumblemarc's Avatar
The Grumpiest
Wrong code maybe?
Now I'm worried.
Old Feb 28, 2013 | 04:33 PM
  #64
OP
Ensure the thickness of those cam gears to stock cam gears. If they are thicker, which in most cases they are, then you'll need to get a slightly longer cam bolts. Failure can case the stock bolt to snap because of the size difference.
Old Feb 28, 2013 | 05:42 PM
  #65
LightningTeg's Avatar
Community Builder
lol That valve cover is silly looking. I would just run stock pulleys.
Your definitely gonna need bigger cams also. Crower (not Brian Crower) 404s are what I run.
Old Feb 28, 2013 | 06:20 PM
  #66
srqslop's Avatar
I'm painting the valve cover for sure!! Valves or cams? The cans are 470 lift on 280* duration. The cans should be big enough to pull 600 out of. For sure!
marcussmith26
Jan 5, 2006 06:36 PM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
GOIN V8 HUNTIN
Nov 8, 2005 06:13 PM
Joel_MN
Aug 29, 2003 11:58 AM
GoldenONE
May 19, 2002 12:05 PM
