B16a 6psi dyno 203whp 139trq
Old 04-27-2009, 11:00 AM
b20beast83's Avatar
Default B16a 6psi dyno 203whp 139trq
Stock Block B16A
Integra Type R CAMS!
Walbro 255 Fuel Pump
Precision 880cc Injectors
Garrett T3 T4 60Trim .63
Tial 38mm WG - 6PSI
Tial BOV
Precision 350whp intercooler
2.5" DP and Exhaust
2.5" Coldside / 2.25"Hot Piping
Ebay Cast Manifold
eCtune
Please tell me what you think about my dyno guys.
203WHP 139WTQ
By jdmking at 2009-04-27
Old 04-27-2009, 11:09 AM
b20beast83's Avatar
Default Re: B16a 6psi dyno 203whp 139trq
How do i find Peak TQ?
Old 04-27-2009, 01:23 PM
AJxr's Avatar
139 is your peak torque... no?
running turd b16 cams? at least get some gsr cams.
but the hp id say is pretty good for 6 psi.
Old 04-27-2009, 01:35 PM
b20beast83's Avatar
oops!
very sorry
should be type r cams
Old 04-27-2009, 01:47 PM
Ls_dx's Avatar
turn up the boost
Old 04-27-2009, 02:13 PM
b20beast83's Avatar
Originally Posted by Ls_dx
turn up the boost
same thing im thinking
Old 04-27-2009, 06:17 PM
b20beast83's Avatar
wow 128 views and only like 2 replys
Old 04-27-2009, 06:19 PM
AJxr's Avatar
6psi is barely anything, run however much it takes to make 350whp and enjoy it.
Old 04-27-2009, 06:57 PM
b20beast83's Avatar
going to see where 10psi takes me
Old 04-28-2009, 01:22 AM
95civhb's Avatar
injectors a tad large... you should turn up the boost like everybody else said...
Old 04-28-2009, 01:41 AM
ACTION JACTION's Avatar
Im going to guess 10psi = 237whp
Old 04-28-2009, 02:10 AM
FastEg6's Avatar
Yeah crank that sucker up and let it rip!!! Let us know how it goes.
Old 04-28-2009, 04:39 AM
b20beast83's Avatar
200hp is weak
a stock intrgra r was barely keeping up
Old 04-28-2009, 04:49 AM
Man U FTW
Schister66's Avatar
You need to turn up the boost. That engine, with a proper tune, can support 300whp with ease. Also, your turbo is a bit large for your power goals. I know it's a little late to tell you that now, but keep it in mind if you're ever considering an upgrade. I had a 60 trim on my first setup and i loved it; however, after doing a little research, i bought a better turbo and it knocked my socks off...the difference in spool and power was amazing. Both setups were on stock block. I went from having a 60 trim to a GT3255b...spool from 4500rpm to 3800rpm and i made more power at EVERY rpm range. It was an awesome investment
Old 04-28-2009, 04:53 AM
blaze the chemi's Avatar
Those numbers are comparable to when I was at 6-7psi on a greddy kit. Crank up the boost to 10 psi for the stock MAP. Your DP could be your biggest restriction. Do you have a pic? Great street turbo choice too.
The DP on the greddy kit sucks. I hit 15 psi with 215wtq, but between 5500 rpm and 8K my boost fell to 12psi. I ended up with 248whp. It was a blast though and pissed off a lot of cars.
Old 04-28-2009, 05:07 AM
b20beast83's Avatar
i do not get traction launching on the street in 1st and 2nd
i dont think i would enjoy a quicker spool
i get boost about 4000rpms, not bad....
Old 04-28-2009, 05:09 AM
b20beast83's Avatar
My dp a mandrel bent 2.5", no tight turns or anything
but it was just a quick tune, im sure i could of made some more power with tuning, but i just wanted to get a baseline before i cranked up the boost to 10psi
thanks for the comments everyone
Old 04-28-2009, 05:14 AM
Top Speed's Avatar
Like everyone else said, turn the boost up!
Old 04-28-2009, 05:23 AM
90civichbsi's Avatar
The numbers seem kind of low for that size turbo. I was making 258 on 7.5lbs with a 50 trim t3/t4. Im currently making 305hp on 10.5lbs. its all about the tune.
if you want it though I have a never used 10.15lb 38mm tial spring I would sell.
Old 04-28-2009, 05:31 AM
lub
lub's Avatar
moar booost...good luck tho.
Old 04-28-2009, 05:33 AM
Man U FTW
Schister66's Avatar
Then you have some shitty tires. My setup was making 315whp/216wtq and had full boost by 3800rpm. No traction problems with my BFGs. I'm not saying you need to increase spool, but that powerband is not "ideal" in my eyes. Not trying to rain on your parade, but things could be a lot better if you care to listen to constructive criticism...
Old 04-28-2009, 05:34 AM
b20beast83's Avatar
the car wasnt fully tuned
3 dyno pulls, and whilest your numbers may be 250 on 7.5psi, different dynos read differently.
I also just bought a tial yellow spring yesterday.
It will be in this weekend
Old 04-28-2009, 07:15 AM
VtecCarHauler's Avatar
what was the timing at? Better flowing exhaust will only help. Hp isn't really that far off for only 6psi on your setup. Try going open dp before you change anything. That will give you a good idea on how good the exhaust is flowing.
Old 04-28-2009, 09:10 AM
b20beast83's Avatar
Timing is 18.5* from 5-6000rpms
20-21* at 6500-7000
18* 7500-8000
19.50 - 9000
how does that look
b20beast83
03-24-2010 10:06 PM
turbohf
12-03-2007 10:47 PM
AzG35
11-25-2004 06:16 AM
Spooled1.6L
03-16-2004 03:06 PM
Snail Tuning
04-15-2003 08:49 PM
Quick Reply: B16a 6psi dyno 203whp 139trq
