b16 turbo questions
b16 turbo questions
Whats up H-T
alright this is not my first time having a boosted car last one was a ls-vtec on 8.2 compression. made 450hp.
i am currently building a b16 (bottom end is finally finished) i want some seriously low compression something like 7.5 or so.. my bottom end is rated for 8.0
Also ihave a spare gsr head i am going to place on my fresh block. (i know it bumps the compression up)
on to my questions..
i want to know can i use more then one head gasket? why or why not
if i get lower compression valves will it counteract the gsr head?
and last but not least.
i was brousing through ebay (its fun) i saw this intake many i liked.
(link)
http://www.ebay.com/itm/Acura-Integra-94-01-GSR-B18C1-B18-Engine-Air-Intake-Manifold-Aluminum-/251257568603?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a801e3d5b&vxp=mtr
Will this help me out with flow a little bit after tune is perfect?
P.s. i would appreciate it if you don't treat me like idk what im talking about. when it comes to Most b series things and things i do not know i come here (Honda-Tech) afterall iv had a boosted daily driven for 3 months
thank you for responding
(link)
The Grumpiest
Re: b16 turbo questions
He's f%$&ing with you because your goal for super low compression and reasons behind it are ridiculous. Two head gaskets? Counteract the GSR head? WTF? My bottom end is rated for 8.0?
I'm just curious where did you get stuff this from?
If I were you my approach would start with...
"Gee. I'm not the first guy to try to build an engine and boost a Honda. Maybe with this vast resource they called Honda-Tech I can just search and find someone that's already done exactly the thing I want to accomplish and just copy that. Maybe along the way I'll learn why they did what the did."
Someone needs to go to the library and stay there for at least a year or two.
This is a good book to read.
The Grumpiest
Nah. I don't understand how people think owning a boosted car somehow translates to them actually being knowledgeable enough to build one and NOT have to do any research along the way.
And before anyone jumps and says "I'm just trying to learn. Isn't that what this forum is for? Asking questions?" the answer to that is yes and no. No because you need to educate yourself first and when you have the only time you should be asking questions is after you at least have a build list and a plan.
inturn i dont wanna "copy" what they do.... its very rare for me to follow somebodys footsteps.. its easy for that.. its not fun doing that... id rather scream at the car for not running right and me build it then follow somebody else and be happy.... its all about pride to me if u get where im coming from
The Grumpiest
Nothing you do is going to break new ground so no I don't get where you're coming from because, frankly, it's utter nonsense. You don't have a clue what you're talking about. That much is obvious. Go and educate yourself and read so you actually understand what it is you're actually trying to do and not just come off like a crazy person.
Cosmetic makes thick head gaskets.
I dont know what your goal is with your car, But you should look into going high comp turbo pistons.
My car is about 10.3:1 CR, out of boost feels like a NA car, Its fun street DD. (Im at 400Whp on pump gas) (my car is NOT Hi CR but I do plan on going that rout)
(a good read https://honda-tech.com/forums/forced-induction-16/muckman%92s-integra-high-compression-super-build-3086196/ )
i do understand where ur comin from.. i got master mechanics in my family. step bro and my brother in law. so as far at specs and tq ratings im fine... none of them hav had a honda and built it
(a good read https://honda-tech.com/forums/showthread.php?t=3086196 )
ehhh i do get that .. .Yah its a honda.... but i believe in my 4cly... its my first car.. been stolen 3 times and i still have it???? dam it means it either loves me... or i care to much to see it rot away. if that makes scence.... im goin 240sx soon. i like the look of a s13
The Grumpiest
yah i want this for drag/show only i can achieve 500hp easy i did it with my 9.5 almost stock ls. lol ... im jus trying to be my own person... honstly. i hate when people tell me i cant do something. just makes me wanna do it even more. also no matter if its a rotary, 2cly, 4cly, 6cly or even 8 if its built.. i will not hate on it ... its about the pride to me.. in the end idc about my 1/4 time.. i care about i put this together with little help besides tuning..... and if i **** it up ok.. time to start again.... btw im only 21
Man U FTW
Your rationale for low compression makes NO sense. You can put more air in the cylinder, sure, but you're not compressing as much...and as such, you're losing power.
You need to learn how static vs dynamic compression works. Just because you can put more air in, doesn't mean it'll make more power.
This could help: http://www.wallaceracing.com/dynamic-cr.php
hatchet_honda
07-06-2009 09:27 AM
X2BOARD
11-07-2002 04:37 PM
