b16 with ls tranny
Old Oct 20, 2004 | 01:20 AM
ieatrice's Avatar
Default b16 with ls tranny
yeah im just wondering if a b16 with a b16 tranny is better to turbo then a b16 with ls tranny i was thinking ls tranny is better becuz of teh longer gears ???
Old Oct 20, 2004 | 05:01 AM
mrspeaker's Avatar
Default Re: b16 with ls tranny (ieatrice)
With the longer gearing of the ls tranny ..U will be in boost longer before you would have to shift to the next gear and have the turbo spool back up...
The Bad part is when u shift the rpms would drop out of the powerband,and u would have to wait for the power again..
But with the b16 tranny u would have great acceleration and everytime u shift u will still be in powerband....
But shifting more causes the turbo to go in and out of boost .....
IMO The ls would be better in High HP/Big turbo applications..
And B16 would be better for smaller turbo/moderate HP applications..
Just My opinion...
Modified by Mrspeaker at 12:35 PM 10/20/2004
Old Oct 20, 2004 | 06:27 AM
MIKES's Avatar
Default Re: b16 with ls tranny (Mrspeaker)
LS trannies belong on LS motors. Period, vtec motors need vtec trannies. I have a B16 with a LS tranny and the gas mileage is decent, but thats about it. Its lazy, laggy and just plain doesn't fit the bill. If you put a LS tranny on yours, get some killer valve train so you can rev the **** out of it so you can still stay in your powerband inbetween shifts. But thats a accident waiting to happen.
Old Oct 20, 2004 | 08:07 AM
g2turbo's Avatar
Default Re: b16 with ls tranny (MIKES)
i also ran a turbo b16 setup with the ls tranny and was not happy with the results. Keep in mind this was a low compression built b16 but regardless it wasnt responsive at all and very laggy.
chris
Old Oct 20, 2004 | 11:07 AM
ieatrice's Avatar
hmm thanks for your oppinion and so i should swap out trannys then correct adn if so then waht tranny should i get teh b16 tranny? and if i have a little bit more money is teh gsr tranny better?
Old Oct 20, 2004 | 11:10 AM
ieatrice's Avatar
also i might plan to swap out teh b16 and put in an ls cuz of the lwo compression but shoudl i also changed trannys? or leave it as an ls tranny?
julio_bOostamante
24
Jan 5, 2006 04:53 PM
Ratchback
Dec 23, 2005 07:42 AM
mrchris386
Nov 24, 2003 07:25 PM
hatchattak
Aug 26, 2003 07:44 AM
Monstuh4U
Oct 29, 2001 06:53 PM
