b16 with ls pistons?? anyone done this?
well i'm building a drag car and i'm on a really tight budget and i have access to honda parts at cost cuz i work for honda. so what i'm thinkin is do a b16 with ls pistons, shotpeened rods with rod bolts and a balanced bottom end (big maybe on that one). c-speedracing tells me that my compression ratio would be around 8.6:1 so i'm thinkin i should be able to run a good amount of boost on race gas (14-16 lbs). keep in mind that this is a gutted drag hatch and it will only see this much boost a couple of times a week during race season. can it be done or will things get all fucked up? i'm new to the FI game and would like opinions but i don't want anyone to tell me to spend more cuz that's not an option. thanks
Re: b16 with ls pistons?? anyone done this? (b16vtecsol)
Not trying to knock you or anything, but if you're on the cheap, why not just throw on a thicker headgasket and be done with it. 8.6:1 is really low. Too low if you're only running 14-16psi.
New User
Re: b16 with ls pistons?? anyone done this? (DSF)
Unless you enlarge the valve relief's on the LS pistons, the valves will hit the dishes. I went that route the first time. It's seriously not worth the time/money/machine work to put LS pistons in an otherwise stock b16a. 10 pounds at 10:1 is MUCH more fun daily driven than 12-14 at 8.5:1
1 Post
Re: b16 with ls pistons?? anyone done this? (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">Unless you enlarge the valve relief's on the LS pistons, the valves will hit the dishes. I went that route the first time. It's seriously not worth the time/money/machine work to put LS pistons in an otherwise stock b16a. 10 pounds at 10:1 is MUCH more fun daily driven than 12-14 at 8.5:1 </TD></TR></TABLE>
hmm.... thats funny, i had no problem and i ran ITR cams.. so i think you are wrong or fucked something up..
