b16 build question
Old Sep 16, 2010 | 10:44 AM
StreetLimitz89's Avatar
Icon2 b16 build question
hey i am buying a 91 crx with a b16a1 engine already swapped into it for rather cheap .. the body is flawless and it just need a decent paint job .. i was thinking about running a boosted setup but i really dont want to boost the stock internals.. i have found a eagle rod and cp piston combo package on eBay for around 700$ ive got the acl bearings and arp head studs and rod bolts getting ready to be ordered ..im looking for a cam shaft setup that will support 10-12 psi of boost fairly decently. im just not sure what i would need for intake and exhaust lift/duration for the turbo setup i want to run further down the road i am looking at buying the darton sleeves to run even more boost and possibly nitro (EVENTUALLY) any ideas on what kind of cam shaft would be decent enough to run this kind of setup?
im also going with a set of 440cc injectors.. for the obd0 swapped to obd1 would i need the low impedence or high for it also as every body does the walboro 255lph fuel pump and a battery relocation to the rear ..
j.packsb
Nov 14, 2009 09:13 PM
killakalipoph
May 20, 2009 09:44 AM
Powelly
Sep 26, 2007 04:22 PM
1gen crxer
Apr 28, 2004 04:37 PM
1RMDave
Jun 7, 2003 02:05 PM
