aries vs je
Old Aug 20, 2002 | 10:02 AM
fastludeh22's Avatar
Default aries vs je
which are better for turbo app.? i will be running HIGH amounts of boost
Old Aug 20, 2002 | 10:16 AM
SiRkid's Avatar
Default Re: aries vs je (93ludevtec)
je
Old Aug 20, 2002 | 10:26 AM
symba's Avatar
Don't quote me on this, but I think Vince at GE is backing Arias pistons now..Double check with him though.
Old Aug 20, 2002 | 10:29 AM
jinxproof99's Avatar
New User
Default Re: aries vs je (symba)
either one.
Old Aug 20, 2002 | 10:57 AM
BoostinDC2's Avatar
Default Re: aries vs je (jinxproof99)
arias
Old Aug 20, 2002 | 12:34 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: aries vs je (BoostinDC2)
<-- went w/ arias
Old Aug 20, 2002 | 12:36 PM
b18bturbo's Avatar
Default Re: aries vs je (vtecvoodoo)
either one is good..
Old Aug 20, 2002 | 12:48 PM
Ri5e's Avatar
Default Re: aries vs je (b18bturbo)
JE or Arias, they're all about the same.
Old Aug 20, 2002 | 12:56 PM
justagsr's Avatar
Default Re: aries vs je (BG Boost)
friend had problems with Arias...
<~~~going with JE
Old Aug 20, 2002 | 03:32 PM
tygsr's Avatar
Default Re: aries vs je (justagsr)
the only issue Ihave heard with JE is they tend to have sharp edges so they need to be sanded down some.other than that they seem awesome..I am running them on my car as soon as it is done..
Old Aug 20, 2002 | 03:38 PM
Boost2NA's Avatar
Yes Vince at GE is carrying arias pistons. Thats who I got mine through. havent driven the car yet with these pistons but hopefully witihin a week I will be breaking it in. My engine builder was very disappointed in the ARIAS rings they way the fit up. But overall I think ARIAS is a very good piston for turbo apps.
Old Aug 20, 2002 | 03:42 PM
20lb.teg's Avatar
Default Re: aries vs je (tygsr)
JE's run a better metalurgy (Metal/alloy content) than aries and are generally stronger as far as off-the-shelf pistons, if you get custom however, they will be as strong as you tell them to make them so you will be the judge. When I was looking for pistons the major comparisons was not aries (they are usually better for NA aplications) it was Wiseco. Wiseco and JE are pretty close in metalurgy and are both very good pistons. Let me know if you have any questions about the specifics of either pistons and actually the best way is call JE @ (714) 898-9763 and ask them their metal/alloy content. than call aries (I don't have a number for them, but I'm sure their website should) and ask them for their metal/alloy content #'s and that should give you a good idea of what they are. I hope this helps.
Later,
Sean C.
Old Aug 20, 2002 | 05:35 PM
Boost Happy's Avatar
I am running JE in my built ls and are happy with them
Old Aug 21, 2002 | 08:30 PM
TurboR1391's Avatar
Default Re: aries vs je (Boost Happy)
I am running JE 9:0:1 now in my R and I have no problem. I ran Arias in my old car a Civic with JRSC B18C1 @ 11.5 psi. Arias are really good pistons but they are a little noisy on startup. I would buy them again if I had to.
Old Aug 21, 2002 | 08:57 PM
markaria's Avatar
Default Re: aries vs je (RreadyBoosted)
how are th 9.0:1 je's on startup? hows the throttle response off boost?
Old Aug 22, 2002 | 12:40 AM
TurboR1391's Avatar
Default Re: aries vs je (markaria)
I have quite alot of turbo lag because of my retarded timing. The JEs are pretty quiet in comparison to the Arias on startup.
Old Aug 22, 2002 | 01:54 AM
sparkz's Avatar
Default Re: aries vs je (TurboR1391)
Kurt of KG told me that Arias now has a different forging method/style/technology whatever are better. From the 3 sets that are in my friends car, I can tell you that there is no noise on startup, even on cooler days. I know theyre old pistons ratteld quite a bit on startup on cold days but their new pistons
Old Aug 22, 2002 | 08:15 AM
ekb18c's Avatar
Default Re: aries vs je (sparkz)
Yes, arias has a new forging and new metalurgy these days. It doesn't sound like a disel truck no more. They used to be very loud but now they are very quiet.
crush
Jun 6, 2005 06:47 PM
respectblades
Jun 23, 2003 09:08 PM
servion
Mar 31, 2003 07:43 PM
Mr. Vapor
Dec 10, 2002 04:40 PM
boosted3g
Nov 7, 2001 01:49 PM
