Apex AVCR boost controller question...
Old Nov 29, 2001 | 10:18 AM
Turboholic's Avatar
Default Apex AVCR boost controller question...
I purchased a used AVCR and was wondering if anyone out there can tell me what their sensor voltage's are. I had my car (95 GSR Turbo... built) on the dyno and it wasn't creating enough boost. So I turned the AVCR up to about 1.5 bar and it still only boosted about 9 psi!!!! A friend looked at my AVCR and said that the voltage didn't look right. Can someone help me out!? Thanks.
Old Nov 29, 2001 | 11:48 AM
MiraiZ's Avatar
Default Re: Apex AVCR boost controller question... (Turboholic)
voltage? aren't all those 12v input?
Old Nov 29, 2001 | 12:20 PM
Turboholic's Avatar
Default Re: Apex AVCR boost controller question... (MiraiZ)
no no no... Im talking about when I have my igniton on and my motor off. On the AVCR if you go into the ect. menu and under the sensor chk. it will tell you the voltage from Boost and from the throttle position. Mine says 1.47v for boost and 0.47v for throttle. Is this normal... cause my friend told me that it wasn't.
Old Nov 29, 2001 | 01:24 PM
93B17A's Avatar
did you check the manual?
Old Nov 29, 2001 | 01:25 PM
Turboholic's Avatar
Default Re: Apex AVCR boost controller question... (93B17A)
The manual doesn't say anything about what it should be. Its very vauge.
Old Nov 29, 2001 | 01:45 PM
TurboIntegra's Avatar
I assume you tried increase your "DUTY" cycle right?
Old Nov 29, 2001 | 01:47 PM
Turboholic's Avatar
Default Re: Apex AVCR boost controller question... (TurboIntegra)
sure did! Im just thinking that there may be something wrong with the unit. If its not too much to ask can someone take a look at thiers and tell me their voltage readings when their motor is off. I know that they should all be in the same ballpark. If its way off then that will throw me a red flag right there. Thanks.
Old Nov 29, 2001 | 05:16 PM
chri5's Avatar
i'll let you know what mine says when i check it in like 15 minutes.
Old Nov 30, 2001 | 07:49 AM
Turboholic's Avatar
Default Re: Apex AVCR boost controller question... (Chris_Turbo)
Thanks man.... I'll apprechiate your reply.
Old Nov 30, 2001 | 08:48 AM
chri5's Avatar
I showed 1.5 boost and .3 TPS last night with the ignition to the on position and the car off
Old Nov 30, 2001 | 08:59 AM
SiR-G96's Avatar
I got 1.45 boost and 0.47 thrt when car off.
Old Nov 30, 2001 | 09:01 AM
Turboholic's Avatar
Default Re: Apex AVCR boost controller question... (SiR-G96)
well dam! Looks like mine is fine. I woder why it doesnt make more boost on the dyno then. Everything else is holding boost (blow-off etc....)
Thanks for the help guys!
Old Nov 30, 2001 | 09:14 AM
VTC_CiViC's Avatar
Perhaps you have a small boost leak somewhere? Try increaseing the start duty in each gear too, does wonders!
turbojdmhatch
Apr 28, 2008 03:02 PM
rice a roni
Nov 20, 2006 06:17 AM
delslo93
Aug 15, 2006 04:50 PM
97turboteg
Apr 11, 2006 10:47 PM
dabrown
May 20, 2003 03:53 PM
