anyone use autometer a/f gauge with zeitronix wb?
how accurate will it be for monitoring if the autometer gauge is wired into the narrowband output? I plan on buying a zeitronix wb, but without the display. I want to tune with a laptop, but not keep the laptop in my car all the time. And I dont want to pay extra for the display.
Re: anyone use autometer a/f gauge with zeitronix wb? (See Are X)
its not very good to tune off the narrowband output using a autometer gauge.....it would be no diffrent than having it hooked up to your stock o2 sensor........
you should spend the extra for the display...its really worth it especially since you cant really drive around and stare at a lap top screen all the time.
depending on what ems your using, it probably wont even give you a reading. i know the aem eugo has a 1 volt wire to run to the autometer guage, but it lights up half the guage at 1 time. so if yours had the same wire then you could wire it up, but i wouldnt expect to see accuracy. if you wanted to keep the guage, there is a little box that will turn your autometer into a wideband guage and instead of bouncing around it will just stay in the one spot and it send a chart to show you where the different ratios are. its only like 30 bucks.
hondaguyexsi
10-08-2005 06:58 PM
