autometer air/fuel c2 gauge
Old Apr 20, 2004 | 10:21 AM
yee SERIOUS's Avatar
Default autometer air/fuel c2 gauge
ok, i'm sure just about everyone has heard enough about air/fuel gauges. especially from autometer. LOL! but i have a friend that is trying to install his. he has a prelude S. but he has the new autometer c2 gauge. and the c2 gauge has a white wire that needs to be connected to a 12v dash lighting. and that's something i don't understand. can anyone clearify that up for me? he needs me to hook it up for him, and i just have no clue how. has anyone hooked up a c2 gauge or a lunar series gauge? i'm still somewhat unsure how to wire up the purple wire to the o2 signal, but i'll figure it out i guess. lol thanks in advance
here is a pdf diagram of the hook up.
http://hp.autometer.com/instru...n.pdf
Old Apr 20, 2004 | 12:19 PM
bumpity bump
someone has to know where to hook up that white wire...ahhhhhh
Old Apr 20, 2004 | 12:56 PM
Burke's Avatar
Banned
Default Re: (LiTtOGPiMp)
pull out the *** where you dim the switches etc. and pull the 12v off there, make sure you get the right one so its dims with the lights. you can screw up and it will be always on or it will act opposite how its supposed to.
good luck
Old Apr 20, 2004 | 02:04 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Burke)
There is also a wire in the radio harness that powers dash lights, I splice off that one..
Old Apr 20, 2004 | 05:08 PM
hmmm...ok...so it just has to wire up to the dimmer switch? am i interpreting this correctly? i'll give it a try.
Old Apr 20, 2004 | 05:12 PM
Banned
Yes, there is one in the radio harness, one under the dash, you can even wrap the wire around one side the panel lights fuse, then put the fuse back in so that it holds the wire.
Old Apr 22, 2004 | 09:49 AM
cool thanks man. i really appreciate your help.
Old Apr 22, 2004 | 04:06 PM
Turbo_EJ's Avatar
Make sure you hook it to the wire with constant voltage. If you hook it to the one that dims your guage light will go dim also.
93IntegraRacer
Feb 10, 2004 07:23 PM
blacksh
Sep 30, 2003 11:50 AM
