S300 launch control help?
Old Mar 10, 2008 | 07:11 PM
Garage 808 Hatch's Avatar
Default S300 launch control help?
wondering where to start on the settings for timing retard and fuel add
Old Mar 11, 2008 | 10:45 AM
PHDZINE's Avatar
Default Re: S300 launch control help? (Garage 808 Hatch)
Start off with -25 for timing and 60-100 fuel. Retard more timing or add fuel from there to see if you can build more boost. If it doesn't, bump the RPM launch limit. One car that I did needed -40 timing and 450 more fuel to build 14psi boost on a S372 turbo
Old Mar 11, 2008 | 01:00 PM
Default Re: S300 launch control help? (PHDZINE)
sweet, thanks
Old Mar 11, 2008 | 03:05 PM
what should i be looking for? air/fuel wise, etc? with -25 and 60 fuel, it makes 10 psi at 6k
anyone else with some input?
Old Mar 11, 2008 | 04:37 PM
LSR-Abuser's Avatar
Any new pics of the car? Did you get it running? This good info I need to start playing with S300 aswell
Old Mar 11, 2008 | 05:19 PM
PHDZINE's Avatar
Default Re: S300 launch control help? (LSR-Abuser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">what should i be looking for? air/fuel wise, etc? with -25 and 60 fuel, it makes 10 psi at 6k
anyone else with some input?</TD></TR></TABLE>
Dont worry about the air/fuel when you are on the two step. You should already be tuned in that area when you are not on the two step. You cant really measure air/fuel on the two step because of the odd fire with the added fuel.
Old Mar 11, 2008 | 07:06 PM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">Start off with -25 for timing and 60-100 fuel. Retard more timing or add fuel from there to see if you can build more boost. If it doesn't, bump the RPM launch limit. One car that I did needed -40 timing and 450 more fuel to build 14psi boost on a S372 turbo</TD></TR></TABLE>
Good info, that's a lot more fuel than I thought.
Old Mar 13, 2008 | 08:26 AM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">what should i be looking for? air/fuel wise, etc? with -25 and 60 fuel, it makes 10 psi at 6k anyone else with some input?</TD></TR></TABLE>
10 psi is a good amount to launch with. I launch my 2500LBS Civic on a S372 turbo and 25" tire with only 8-9psi at 8300RPM.
v8killaz
Sep 9, 2012 03:00 PM
adam00
Mar 3, 2009 02:57 PM
kaj
Jan 21, 2006 12:07 PM
Ex-ITR5874
Jun 20, 2002 03:15 PM
