Any ideas?? (coolant problem)
your block is o-ringed? did you have them replaced (the o-rings)? you can only get one shot out of them i believe... also are they copper? i can't believe only one person mentioned this.. also what kind of headgasket are you using? i recommend SCE titan and get a o ring kit from them while you are at it! also they recommend re-torquing the head!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i can believe that. I was gonna say that becuase i had the same set up , same can i think. Did you do the Endyne?</TD></TR></TABLE>
i have a greddy, i need to know how set it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">heres how i run mine.. no valve cover breather filter and no filter on oil catch can.. although i don't know if it will help at this point
I dont have a stock manifodl anymore. No more pcv valve..
Did you hook your oil catch can to the black box?
</TD></TR></TABLE>I dont have a stock manifodl anymore. No more pcv valve..
Hey guys I wanted to shed some light on a similiar problem that I am having. First off, I too have Benson sleeves 84 mm bore. My valve cover looks exactly the same as yours Jordan. I dropped the oil pan and found my oil to be fine, there is no milkyness or milky color to it, just plain oil. I took my oil breather box (I think that is what its called) off the back of the block, and it was full of the milky stuff too, but it also had water in it. Its not coolant, it is clear. I am loosing some coolant out of the resivior though. I thought that I was the only one with these problems, but it looks like there is a few of us. I am going to put some Barrs Radiator stop a leak in and monitor it for a few days. I will let you know what I find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18Jay »</TD></TR><TR><TD CLASS="quote"> I am going to put some Barrs Radiator stop a leak in and monitor it for a few days. I will let you know what I find out. </TD></TR></TABLE>
Save yourself the headache. I've tried that and it didn't work. Has anyone tried just running the stock PCV setup without a catch can? I didn't have this problem when I had only a DRAG turbo kit. Basically I just had the breather filter on the valve cover with no other mods to the stock PCV system. When I started getting creative with the PCV system is when I noticed the problem.
EDIT: It still doesn't explain why the coolant is disappearing on a consistent basis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo »</TD></TR><TR><TD CLASS="quote">
do all of you guys have stepped deck blocks??</TD></TR></TABLE>
Yes.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll »</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
i think thats the problem
Not enough clamping force on the head gasket?
my block is stepped also , but i dont think that is the problem , cus it is only stepped .003 of an inch , if you have had your heads or blocks surfaced , have you sortend your dowel pins ??? cus it could hold the head up , but i think i would pressure test the block next and check the sleeves , my car is back together and running so i will see if i have any issues ,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">my block is stepped also , but i dont think that is the problem , cus it is only stepped .003 of an inch , if you have had your heads or blocks surfaced , have you sortend your dowel pins ??? cus it could hold the head up , but i think i would pressure test the block next and check the sleeves , my car is back together and running so i will see if i have any issues , </TD></TR></TABLE>
I was told by Earl that if you stated your car was to be a street car the step deck was reduced to .002". I asked Earl and Dan about the dowel pins and they both told me it was not necessary to shorten them. That was in the back of my mind the entire time. Let us know how it goes with your car.
yes i will let you guys know how it goes , cus i better not have any issues with it , and i did say it was a street car , but any way time will tell , now i just need the weather to change and to get my retune ,
I feel your guy's pain. Here is the one key element. Not one of you guys have had milky oil IN THE PAN. That is where the sleeves would be leaking, so I don't think it is a sleeve problem.
Things in common are a modified breather system, many complaints coming from costal areas (Gulf Breeze FL, San Diego CA, Louisiana, etc) and a slight loss of coolant.
Remember coolant can be pushed out of the radiator by pressure (micro head gasket pressure leaks into the cooling?), just a guess.
Milky valve cover can be caused by cool, moist air being sucked in the cover because of the fresh air breathing system. It mixes with the oil mist flying around in the valve cover area and becomes milky.
A key here is what B18Jay said. Kevin is running a 50-50 coolant mix but PURE water is coming out of his breather box, not a 50-50 mix. This is why I feel the milky valve cover is being cause by the breather.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">I feel your guy's pain. Here is the one key element. Not one of you guys have had milky oil IN THE PAN. That is where the sleeves would be leaking, so I don't think it is a sleeve problem.
A key here is what B18Jay said. Kevin is running a 50-50 coolant mix but PURE water is coming out of his breather box, not a 50-50 mix. This is why I feel the milky valve cover is being cause by the breather.</TD></TR></TABLE>
that makes alot of since, but why are we all losing coolant??
would lose of coolant have anything to do with the breather system???
my money is on the stupid step deck
well mine was oil in the coolant i never had any milky crap in the oil at all , but when i took my head off the 2 middle studs where loose, my breather system is baffled , wich i know the greddy is not and endyn i dont think is eather , but i was missing coolant to but i live in upsate ny so no coast here , i realy hope we can all put are heads together and figure this out ,
