Thermostat
Old May 8, 2007 | 05:20 PM
jdmturbo1127's Avatar
Default Thermostat
What would be a good thermostat to use for the summer months when the air is pretty dry and the weather on average is between 85-100 degrees during this time? Has anybody tried running without a thermostat during summer? What are the pros and cons?
Old May 8, 2007 | 05:33 PM
tony413's Avatar
Default Re: Thermostat (jdmturbo1127)
whats the set-up on your car if its not tuned or atleast has a mild tune stay stock and never run any car with a stat even in alaska your car would still be likely to over heat
Old May 8, 2007 | 06:51 PM
Default Re: Thermostat (tony413)
D16 with minor bolt ons. Soon to be boosted however. Why not run a thermostat? Will my motor actually stay cooler? I was told not running one during the winter months will keep my heater from making enough hot air to keep the cabin warm.
Old May 8, 2007 | 07:01 PM
tony413's Avatar
without the stat your just gonna run very rich an the motor is not really gonna warm up. and it is possible to run to rich when this happens you get the same effects of preignition and detenation
Old May 8, 2007 | 07:12 PM
Running rich would seem to be a bad thing for me, am I right? You still say dont run one. Im confused? Why not use one if this is the case?
Old May 8, 2007 | 07:46 PM
tony413's Avatar
NO im saying you NEED one at all times no matter what the weather conditions. running without it is bad for your engine. the reason racecars dont run one is because they are constantly moving at a high speed if your car is a DD you need the stat
Old May 8, 2007 | 09:13 PM
Default Re: (tony413)
Oh I see, I read your first reply all wrong. Thanks for the tip
Dontoh
34
Aug 1, 2011 04:16 AM
LL_SP4RROW
Jun 3, 2011 10:00 AM
JDMJAYDC2
Apr 23, 2007 08:44 AM
str8boost
May 1, 2005 04:52 PM
