Alternative fitting for oil feed
Old Aug 10, 2003 | 09:31 PM
dualknuttz1's Avatar
Default Alternative fitting for oil feed
What fitting is everyone running now on the oil feed for the turbo. I'm using the 90 degree brass and it doesn't seal completely (i used teflon tape). it is slightly leaking. I want it to face towards the rear so the line can be screwed on easily. Is there something out there in the market similar to the brake lines, where there is a hollow bolt and it just screws in around a ring? Ohh like the tial wastegate vacuum line adapters.
Old Aug 10, 2003 | 09:43 PM
1fstevo's Avatar
New User
Default Re: Alternative fitting for oil feed (dualknuttz1)
Is that brass fitting has an AN adaptor ends? Because your feed line is an AN line and need an AN adaptor to not leak.
Old Aug 10, 2003 | 09:47 PM
rjardy's Avatar
Default Re: Alternative fitting for oil feed (Evo Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evo Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Is that brass fitting has an AN adaptor ends? Because your feed line is an AN line and need an AN adaptor to not leak. </TD></TR></TABLE>
No it does not, thats why its leaking im sure.
Rob
Old Aug 10, 2003 | 09:48 PM
tegasaurus's Avatar
that's why it leaks... its not an AN fitting.
Those bolts you're refering to are called banjo bolts. It would be hard to find them in AN fittings but im sure they are out there.
-ryan
Old Aug 10, 2003 | 10:34 PM
Accord94DX's Avatar
Default Re: Alternative fitting for oil feed (tegasaurus)
my hks kit came with banjo bolts, i might have extras
PinoyDelS0l
Aug 30, 2009 12:43 AM
stackz
Feb 28, 2008 01:49 PM
B18 CYA
Apr 21, 2004 04:34 PM
beepy
Mar 1, 2004 09:26 PM
DEVIN22CBR
Feb 5, 2004 04:08 PM
