Are All GM 3 bar map sensors the same
Old Mar 8, 2006 | 05:47 PM
Topdawgg's Avatar
Default Are All GM 3 bar map sensors the same
Im pickin one up off my buddy, and im just wonderin if they were all the same?
Old Mar 8, 2006 | 06:15 PM
Everyones Hero's Avatar
Default Re: Are All GM 3 bar map sensors the same (Topdawgg)
Bump because I'm looking for a 3 bar right now.
Old Mar 9, 2006 | 09:46 AM
Topdawgg's Avatar
bump
Old Mar 9, 2006 | 10:04 AM
.nate's Avatar
http://www.robietherobot.com/storm/mapsensor.htm
Old Mar 10, 2006 | 09:48 AM
Topdawgg's Avatar
I can pick up a 2 bar... is that the same thing basically, just rated less...
im only runnin 14-16psi
Old Mar 10, 2006 | 10:37 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">I can pick up a 2 bar... is that the same thing basically, just rated less...
im only runnin 14-16psi</TD></TR></TABLE>
2 bar will only read up to 14.7psi.
Old Mar 10, 2006 | 03:30 PM
hpfsi's Avatar
Haven't looked in a while but I want to say there are three different part #'s for the gm 3 bar, I'd have to check the aempro software (don't have it on this pc) for the specs but I believe they do read a slightly different pressure range. I might be off base though so somebody check their map sensor config menu.
Old Mar 10, 2006 | 04:20 PM
liam821's Avatar
25 Year Member
Default Re: Are All GM 3 bar map sensors the same (hpfsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">I believe they do read a slightly different pressure range.</TD></TR></TABLE>
You are right on. From one 3bar to the next they can read slightly different. This is a GM part remember? What do you expect!
FWD_BEAST
Oct 9, 2012 04:24 PM
TeggieeTuner
Nov 30, 2009 10:02 AM
AJxr
Engine Management and Tuning
Oct 2, 2008 10:12 AM
RACEPAK
Jul 23, 2006 02:32 PM
-iLLuZioN-B18C1
Sep 18, 2003 11:08 AM
