specific oil fitting help
Old Mar 13, 2004 | 09:22 PM
Tad's Avatar
Tad
Default specific oil fitting help
hi,
I was wondering if you guys might give me a hand ordering fittings for my oil feed setup.
I already have the oil feed line, and fitting for the turbo,
I need fittings for the block.
what I want to do is run the line directly to the block,
no T's or anything like that(sensor will have to be left out for now).
now i'm not sure exactly what kind of oil line i have, cept that its stainless steel so I assum its AN.
the red portion of the end of the line has this engraved on it
...=A FC1246-06
can someone tell me the size of pipe I have? is it -6AN ??
from what i've read,
the hole on the block is BSPT correct?
SO i'm really hoping that there is a BSPT to AN adapter fitting.
that would be peeerrrfect.
I dont mind getting a BSPT to NPT & a NPT to AN though if I have to.
but I need to know what size pipe I have, and what size the BSPT hole in the block is.
I have a d15b7.
thanks so much!
OH and is there anywhere else to look for this stuff other than summit racing?
Old Mar 13, 2004 | 09:29 PM
Bailhatch's Avatar
Default Re: specific oil fitting help (Tad)
AN is just 16ths of an inch. -3 AN = 3/16 inside diameter, -4 AN = 4/16 ID...
maybe you can measure it and see. The best place I have found to get fittings is Flamenco T (Stan) on here. If you PM him I'm sure he can help you out and he always ships super fast
Old Mar 13, 2004 | 11:32 PM
dfoxengr's Avatar
Default Re: specific oil fitting help (Bailhatch)
u have to have a T, without the sensor youre in trouble. PM me and ill hook you up with the right stuff.
Fastjato33
Feb 2, 2009 08:22 PM
mrx
Oct 30, 2005 09:08 AM
FOrSfEd
Aug 13, 2004 12:03 PM
reignofchaos
Aug 3, 2003 10:24 PM
B18Flip
Mar 23, 2003 10:32 AM
