Oil return line size and type?
Right now i got -10 AN compressor fittings that been leaking forever.. i'm sick of adding oil and switching to rubber line with clamps and heatwrap. Besides, braided return line is rubber on the inside.. so not much difference at least it will seal
Now, heres my question. I searched and some say to use 5/8 some say 3/8.. which should I get? Also, would red heater hose be good enough for oil?
Thanks
Thanks
Re: Oil return line size and type? (vtec.dc2)
some say 5/8 and some say 3/8 for what????
Use a hose that is rated for oil and can withstand the temps. Anywhere you find the right hose will be able to tell you if it is rated for these things.
The rest of your question I can't figure out.
Re: Oil return line size and type? (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy »</TD></TR><TR><TD CLASS="quote">are you asking 3/8" or 5/8" FITTING SIZE?</TD></TR></TABLE>
i'd like to know what diameter (in inches) i need to run for my return line. fittings i have are -10 AN
get some 1/2" high pressure hydraulic hose from your local industrial center.....that stuff is the same thing the "braided" hose is made of just it doesn't come braided....and its only a few bucks a foot.....
i'm not going to.. guess i'll wait till monday.. i think they had larger heavy duty hoses.. like 3/4" or 1/2".. do i need to change fittings as well or i can just clamp it over existing -10 an
yep.. i'm gonna take apart then.. damn... i had a chance to get larger hose i just wasn't sure.. now gotta wait another day. that 3/8" was the largest in red hoses, but i guess not large enough
. thanks for helping out again
i3oricua
04-28-2004 10:38 AM
