AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed?
I ordered this:
after reading a couple of thread about the AC Autotechnic and the Golden Eagle block adapters. The main purpose for me is to connect the sending units for my VDO oil temp and pressure gauges.
I was thinking about using for the turbo oil feed line in my upcoming turbo project. The problem is the oil source is unfiltered. Is that a major issue?
http://www.we-todd-did-racing....3D%3D
Re: AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed? (creechrr)
Don't worry, no oil in the engine is unfiltered. You're simply taping an oil source that comes before the filter, but that dosen't mean that the oil wasn't passing though the filter 30 seconds before it got there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creechrr »</TD></TR><TR><TD CLASS="quote">I ordered this:
Where did you buy it from? How much?
Cool. Thanks.
Do you have to drill out the holes you are going to use? Or are they all drilled out for you? How many ports does it come with?
Re: AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed? (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip »</TD></TR><TR><TD CLASS="quote">Pretapped with 4 holes....1/8npt i believe</TD></TR></TABLE>
Is there such a thing as a 1/8npt plug? Sure there is just checking.
Re: AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
Is there such a thing as a 1/8npt plug? Sure there is just checking.</TD></TR></TABLE>
Yes, that's the blue thing at the top of the brass "T".
Okay so I went to the site and I want to order one, but who the heck do they know what motor you have or what car or anything about your application? It just says order, I mean there are different oil filters out there. I want one but im kinda at a standstill..............any help?
Rob
Rob
Re: AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed? (rjardy)
last i noticed ALL honda oil filters are the same, whether a Honda Oddessy, Integra, Civic, blah blah etc - look at the book next time ur at autozone, u'll see what i mean, they are ALL the same filter for all honda/acura
Re: AC Autotechnic: Aluminum Engine Oil Filter Block and oil feed? (SolidSpruce)
Is there a rubber gasket that goes against the block to prevent leakage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">Is there a rubber gasket that goes against the block to prevent leakage?</TD></TR></TABLE>
Yes there is.
Yes there is.
Xerxes
08-28-2004 02:02 PM
