__________OIL RETURN LINE PROBLEM, HELP?__________
Old Jul 15, 2004 | 11:25 AM
quick gixxer's Avatar
Default __________OIL RETURN LINE PROBLEM, HELP?__________
Alrighty heres my problem..... I have an 89 civic hatch w/ b16 swap and im doing a junkyard turbo setup. I am using the very flamed SSautochrome manifold and a t3 turbo, my problem is that the oil outlet is coming down in front of my front cross member so if i try to get a path back to the oil pan the line will have to dip down then come back up over the cross member and then back down to the pan... This i believe is no good.... The only thing i can see doing is to cut the cross member and i really don't want to damage the structural integrity of that part.... I know someone out there has had this problem before, please help me out.... Thanks for your time
Old Jul 15, 2004 | 11:42 AM
Default Re: __________OIL RETURN LINE PROBLEM, HELP?__________ (quick gixxer)
helppppppppppppppppp
Old Jul 15, 2004 | 11:45 AM
Blown90hatcH's Avatar
Be patient, clock the turbo, have a nice day.
Old Jul 15, 2004 | 11:46 AM
PrecisionH23a's Avatar
you will have to chop up your front cross member or find a different location on the pan to weld the bung in place.
Gravity is the only thing that drains the oil, so if your line goes up than you will sooner or later blow your oil seals due to improper drainage. Remember, when clocking you dont want anything larger than a 15 degree angle.
Old Jul 15, 2004 | 11:56 AM
you can clock the turbo so the oil outlet is facing a different direction????? I did not know that.... I thought you could only clock the compressor housing????? Am i wrong?
Old Jul 15, 2004 | 11:57 AM
By the way thanks for all the help
Old Jul 15, 2004 | 12:10 PM
FOrSfEd's Avatar
Yeah you can clock the oil drain as well as the compressor, I had to do it. Pretty easy
Old Jul 15, 2004 | 12:19 PM
Default Re: __________OIL RETURN LINE PROBLEM, HELP?__________ (FOrSfEd)
sweet going to do it right now!!!!!!! Thanks a lot guys!!!!!!
Old Jul 15, 2004 | 01:16 PM
clocked the turbo... worked perfectly..... had to bang it with the hammer a few times but it broke free right away... Thanks for all the great insights and quick responses.... turbo Ef is back on track
Type-ARR
Nov 8, 2007 04:22 AM
kameleon23
Oct 5, 2006 03:14 PM
StolenTeg
Aug 25, 2005 03:40 PM
airwalk07143
Jan 25, 2004 03:00 PM
Racer X
Dec 1, 2002 02:34 AM
