83mm vs 84mm Pistons?
Hello everyone,
I've blown my piston rings and I'm not sure how bad the damage is, but my compression is 90 in 2 cylinders I have a sleeved block at 81.5mm right now. My question is, if the cylinder walls are damaged and I have to re-bore should I go with 83mm pistons or 84mm? I like the advantage of quicker spool and more torque with the 84s but if I have this problem again I’ll have to re-sleeve the block. Is there enough of an advantage to go with the 84s over the 83s?
Thanks
Thanks
Re: 83mm vs 84mm Pistons?
85mm is the limit on boost typically, and you typically rebore in .5mm increments so you would have the 84mm build, the 84.5mm build and the 85mm build left if you go 84mm.
Thanks for the advice guys. I forgot to add this is a B18 if that matters. I thought 85mm was too large for boost?... I guess not. Has anyone run both, what kind of spool difference and torque could I expect? Im running a 3076r
85x89mm is a true 2.0L, it will make a little more power than an 83mm, you already have a 30R so it should spool fast as hell already. My friend put 10,000+ miles on his 85x89 at 550+hp daily on corn and its still running.
I would never go 85mm in a forced induction application. If you scuff a cylinder wall or something....time for a new block. 85 is huge and is about max even for N/A application. Stick with the 83 or 84 to leave room for the errors. It also would depend on who sleeved the block as to how much sleeve thickness you will have after re boring it.
You're not going to see that noticeable of a gain from 83 to 84 or even from 82-84 It's just not a huge difference. Besides, that's why you have the block sleeved, so you can crank the boost!!!
85mm is far from max for NA Apps...........
People run 40+psi in 85mm stuff, where are you getting this incorrect info from??
1 Post
Go with 84, men with large ********* go with 84. Yeah 82 or 83 leaves more room to fail but how many times do you plan on failing before giving up...
40 psi is HUGE!!!! who are these people?
Thanks for the input guys. I have an AEBS block if that matters. Youre right, these are expensive fails so Im not sure how many times I want to do this. If i blow the motor again I may move onto another project
m R g S r
04-23-2004 04:46 PM
