84.5mm vs 81mm
Old Apr 24, 2002 | 05:26 AM
Cyber ITR's Avatar
Default 84.5mm vs 81mm
hmm isnt the cylinder walls with 84.5mm pistons will be thinner than 81mm pistons ?
will the sleeve with 84.5mm pistons can hold 20psi+ if it tuned properly ??
Old Apr 24, 2002 | 05:52 AM
newsense's Avatar
New User
Default Re: 84.5mm vs 81mm (VTEC_SiR)
Golden Eagle say their blocks are good up to 85-86mm...
Old Apr 24, 2002 | 06:06 AM
dbman96's Avatar
New User
I believe when you sleeve and bore to 84.5, they install thicker sleeves to begin with, and those are braced against the inside of the block for their full length.
Old Apr 24, 2002 | 06:41 AM
jamal-188's Avatar
Default Re: 84.5mm vs 81mm (dbman96)
I believe there are a number of people that sucessfully run 84.5 mm pistons w/ no problems. I think that's what I'm gonna use when I find a spare block to send to GE. With proper tunning GE sleeves are pretty much indestructable.
Old Apr 24, 2002 | 07:22 AM
Flamenco-T's Avatar
Default Re: 84.5mm vs 81mm (jamal-188)
if you look at their paperwork that comes with your block, it says...
for turbocharging vehicle, do not exceed 60 psi of boost, otherwise you will void the warranty...
LOL
wonder what 60psi feels like....
Old Apr 24, 2002 | 07:50 AM
jamal-188's Avatar
Default Re: 84.5mm vs 81mm (Flamenco-T)
Yeah I bet it's about enought you break your neck from whip lash!!
Old Apr 24, 2002 | 08:02 AM
Finest's Avatar
Uh, what turbo can even provide 60psi ofboost?! T-100? Y2K?!
Old Apr 24, 2002 | 06:41 PM
Cone's Avatar
Default Re: 84.5mm vs 81mm (Prelude_RCR)
I belive Garrett GT35 does 60 psi, and their GT42/45 can do 75 psi I think...I forgot where I read it, but I remember my eyes widening...800hp+ potential...60psi turbos aren't that uncommon, it's the engines that are built to withstand 60psi that are. I think HKS' Supra GT Twins kit has turbos that can do 60psi, but I forgot...its been a while since I have been reading about anything about a T3/T4 hybrid...
[Modified by Stealth 95 GS-R, 10:43 PM 4/24/2002]
[Modified by Stealth 95 GS-R, 10:44 PM 4/24/2002]
E85B18
Sep 21, 2009 09:59 AM
camlob
Apr 22, 2006 01:42 PM
fastcivicboy
Mar 21, 2005 08:51 AM
myDC4rox
Jan 17, 2005 10:35 PM
b_jamin
Mar 19, 2004 02:55 AM
