is 8 psi safe on this setup.
Old Jan 27, 2006 | 06:00 AM
97grnrs's Avatar
Default is 8 psi safe on this setup.
i have a rebuilt to stock spec a6 block and a z6 head. new rings etc... but all stock parts. compression is 9.7 to 1 , ill be using an fmu (12:1) and high flow fuel pump. i wanna know if i can safely run 8 psi on this setup or should i keep it around five? it will be intercooled too. FMIC..
Old Jan 27, 2006 | 06:29 AM
trickeng's Avatar
we run 8-10lbs on those motors stock without any issues. so Yes 8lbs is fine.
keep in mind its all in the tune and the efficiency of your turbo kit.
good luck.
CRXLST
Oct 29, 2004 07:50 PM
taejin11
May 14, 2004 10:57 PM
boostincoupe
Sep 11, 2003 12:53 PM
Rah Rah
Feb 24, 2003 06:03 PM
B17aTrbo
Jul 8, 2002 11:36 PM
