8:5:1 LS Turbo @15psi well made 322whp!!!!!
Beeyond Engineering did it again!!!
1993 LS with 8:5:1 SRP pistons, Eagle Rods, Stock Sleeves, OEM honda Bearings, OEM H.G, Stock head, 3 bar map sensor, aem fpr, aem fuel rail, and 880cc injectors. Beeyond Engineering Turbo kit with Beeyond Engineering Top mount with T3/T04E 57trim (ebay turbo, he was on budget). But it did the job... made 322whp.
A/F ratio was around, 11.3-11.6 on top end. But since we are in state of wisconsin, it was very cold lol. 25degrees.
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">I fail to see the amazingness of this...my STOCK BLOCK GSR made 7whp less than your built block....should i celebrate?</TD></TR></TABLE>
I fail to see the amazingness of your gsr.... 7psi w/ gt32??
this car was with straight LS.
this car owner had Ls/Vtec mild built last year... ran 11.1@126mph with 360whp. He probably can out drive you my friend. Other than, on a LS w/ so low compression made this power, its pretty impressive.
Man U FTW
Re: (95exdsmkilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95exdsmkilla »</TD></TR><TR><TD CLASS="quote">
I fail to see the amazingness of your gsr.... 7psi w/ gt32??</TD></TR></TABLE>
You would...if you would have read my sig, which you'd have to do in order to know i run a GT3255, you'd also know it was on 10psi. Regardless, there is no tech in this thread
jdmhondanation
05-08-2011 08:07 AM
