60-1 opinions
Old Nov 20, 2002 | 03:22 PM
DRAGLS's Avatar
Default 60-1 opinions
Modified by DRAGLS at 7:35 PM 1/5/2007
Old Nov 20, 2002 | 03:25 PM
RyanAutry's Avatar
Default Re: 60-1 opinions (DRAGLS)
No... Should be great...
Old Nov 20, 2002 | 03:28 PM
SiRkid's Avatar
increased spool up..GT30!!!!!!
but you should be alright!
Old Nov 20, 2002 | 03:37 PM
ninesecrx's Avatar
I personaly think that is overkill. Cause my guess is that if your redline is at 7000- your not looking for big power either so why not get a smaller turbo, let it spool up faster and be in your power band for a longer time. Doesnt make any sense to run that size turbo with that redline, your just giving up time you could be at full boost.
Old Nov 20, 2002 | 03:40 PM
Boostfed's Avatar
New User
Default Re: 60-1 opinions (ninesecrx)
Yeah what Mike said, maybe a T3/T04B with Super V wheel .63 A/R turbine housing, Stage 3 wheel. Even a T3/T04E maybe 54 trim and same turbine specs. Laskey Racing did some great numbers with a 54 trim
EDIT: Spelling errors me
[Modified by Boostfed, 7:40 PM 11/20/2002]
Old Nov 20, 2002 | 03:53 PM
C-Murdock's Avatar
Default Re: 60-1 opinions (Boostfed)
ive heard the 60-1 blows out hot air at 15+psi....
Old Nov 20, 2002 | 04:05 PM
HXMan's Avatar
Default Re: 60-1 opinions (C-Redrum)
Dont think so. The turbos that come with stock Mistu cars blow hot air at 15+psi.
Old Nov 20, 2002 | 04:09 PM
Boostfed's Avatar
New User
No a smaller turbo will become more inefficient at higher boost levels than a bigger turbo since the wheels will be spinning faster and heating up. Bigger turbo=runs cooler, now if you go to big then you can get out of the efficiency range of the turbo and actually get Compressor surge. Which the 60-1 might do on a stock LS Redline but st00pid has had success with the turbo, He's turned the boost up and maybe raised the redline some too though, he would have to speak on it.
Old Nov 20, 2002 | 04:13 PM
FFDragger's Avatar
New User
Do u guys think a 60-1/t3 stage v .63a/r is a over kill for an LS w/ a 6800rpm redline?
If not what are some ways to increase spool up on it even if it a few hundred rpm?
I'm thinking about going with this turbo too. But wouldn't a .63 A/R stage III or even a .48 A/R stage III be better for an LS?
Old Nov 20, 2002 | 04:49 PM
paulzy's Avatar
I think when most people say that, they are reffering to the super 60 t3
Old Nov 20, 2002 | 04:50 PM
fastludeh22's Avatar
Default Re: 60-1 opinions (FFDragger)
i just bought a t3 60-1 w/ 83 a/r...but this is for a built and bored h22..we'll see how it does once the engine is back in and broke in
Old Nov 20, 2002 | 05:25 PM
T-sohctec's Avatar
Default Re: 60-1 opinions (HXMan)
ummm... yeah T-3 60-1
right....
I'm sorry HXMan's avatar is distracting me
all I can say
That's one helluva ***!!!
Old Nov 20, 2002 | 05:32 PM
ninesecrx's Avatar
[QUOTE]Yeah what Mike said, maybe a T3/T04B with Super V wheel .63 A/R turbine housing, Stage 3 wheel. Even a T3/T04E maybe 54 trim and same turbine specs. Laskey Racing did some great numbers with a 54 trim
QUOTE]
Yeah, we made like 445 hp at the wheels on that guys car with a t3-t4e with a 54 trim. Even thats pretty big for a stock ls. Maybe like a 54 trim. Why not have fun with the boost all through the rpm band then just have it come on strong at the top.
Old Nov 20, 2002 | 06:13 PM
Boostfed's Avatar
New User
Default Re: 60-1 opinions (T-sohctec)
right....
all I can say
Not to get off topic but I have to agree with you on that fine ***
Old Nov 20, 2002 | 06:15 PM
HXMan's Avatar
right....
all I can say
heheheheh.
Old Nov 20, 2002 | 07:10 PM
DR. ON POINT's Avatar
Banned
I have a 60-1 on a stock ls motor, 440's, 3in dp and Hondata.......at 5psi I ******* love it....perfect for daily driving....I love 60-1's
Old Nov 21, 2002 | 04:17 PM
arjusmc's Avatar
Default Re: 60-1 opinions (ON POINT. EK FOR SALE)
when do you start hitting boost with your setup, and when are you at your peak hp?
Old Nov 21, 2002 | 04:31 PM
Adi Radoncic's Avatar
On Fire!
Default Re: 60-1 opinions (arjusmc)
I like mike would tell you that the 60-1 is way over kill for your stock reving b18b motor and I would also recomend you going with either a 54 trim or if you really want a 57 trim but the 60-1 is very laggy up to 5000 or 5500 rpm depending on your other turbo components.
If street driving is mostly what you care about and ocasional track use I would just go with the 54 trim and be happy with it but if you want some more power go with the 57 trim...
Right now I personally think that the 60-1 is just totally hyped up because it kicks in so late and feels good when it does but what good does that do you when you only get about 1500-2000rpm of boost per gear, if you like to mess around on the street with your frined and wanna put down some vettes or whatever going with either the 54 or 57 trim would be the best thing you could do...
Adi
jdm_vtec
Nov 17, 2006 03:37 PM
ScottEK
Dec 10, 2003 10:15 AM
bluedelsol
Jun 14, 2003 11:37 AM
InfamousRS
Nov 25, 2002 12:53 AM
legendboy
Nov 14, 2002 06:50 PM
